2004 dodge ram 1500 no transmission gears
Old May 8, 2024 | 08:25 AM
Jesus7221's Avatar
Jesus7221
Default 2004 dodge ram 1500 no transmission gears
So i am having an issue with my truck. I was driving about 45 miles per hour and i suddenly lost gears, my rpm's went really high and i tried placing it on 1 and 2 to see if i could manually get anything. I towed it home, checked the codes and had input speed sensor error and output speed sensor error.
I dropped the pan and the fluid was good and the magnet was clean.
Not sure where to go from here
Old May 8, 2024 | 08:54 AM
Which engine/trans?
Old May 8, 2024 | 08:56 AM
Jesus7221's Avatar
Jesus7221
Which engine/trans?
5.7 hemi, and the 545RFE
Old May 8, 2024 | 09:11 AM
Any work been done to it lately? (aside from what you have done after the problem showed up.)
There are MANY possibilities there..... anything from a poor seal at the filter, to a failed pump, or toque converter......
Old May 8, 2024 | 10:54 AM
Jesus7221's Avatar
Jesus7221
Nothing at all unfortunately, i guess i will try and see if a used torque converter from LKQ willl help. I appreciate the help regardless
Old May 8, 2024 | 11:19 AM
That's a lotta work for a guess...... I would be tempted to have it towed somewhere, to have it properly diagnosed.....
