no crank no start C-Codes AA and AB
so long story short i’ve rebuilt my truck from the frame up, it’s ready to start but it won’t even make a noise when turning the key, i got it to show C-Codes, it’s showing AA and AB which is PCM and TCM messages not received, it there anything i have to check or do to make this go away ANY help is greatly appreciated
PCM has nothing to do with the cranking circuit. It's all about the relay. I don't know if the relay's in yours are removable..... but, Trans in park, ignition in start position, (a second warm body makes this a LOT easier....) you should see 12 volts on pin 85 of the relay socket, and pin 86 should go to ground. Either being missing will result in a no crank condition.
Are you sure that a 46RE??? and not the 45RFE??
i’m not too sure on the trans, that’s what i thought it was but also i ran into way bigger problems, i added 2 grounds, 1 for the PCM 1 for the ECM checked all motor grounds and some other computer grounds, all good, but after i turned the key again and got the terrifying “no bus” message, and i have no idea what causing it or where to start, or even fully know what that means, i called the dealership and they said “i don’t even know what that means” so no help there
