5.7 blowing smoke and loud knock at high rpm
Hello all. This is my first thread on here but have read many that have helped. Hoping you all can help me today. I bought an '03 1500 4x4 Laramie with the 5.7 hemi. It ran, but barely. Once I trailered it home and looked closer in the daylight, there wasn't any oil in it. I filled it and now it smokes and knocks loud at around 3k rpm. It barely idles and absolutely no power at any range. The girl I bought it from said the truck had been put on its side. She also showed me the print out from an O'Reilly scan. It said the MAP sensor needed replaced, fuel injectors 5 circuit open, injector circuit cylinder 6, and fuel system 1/1 rich. I assume there is alot going on, but the knocking and smoke have me concerned the most. From what I've seen on other threads I will do a compression check tomorrow. If anyone has any ideas I would be eternally greatful.
Thank you for the insight. While its not good news, it is what i figured and was afraid of. I hoped that with the knock and smoke only showing up at around 3k rpm that maybe it wad a valve spring or something of that nature. Wouldn't the knock sensor have kicked in and put it in limp mode? Just no telling how long she ran it with no oil. I plan to do a compression check today.
Well, ..... more bad news. I put air pressure in cylinder 1 and its not pressurizing. Most of the air comes back out the oil filler tube, but there is a very small amount that also comes out the dipstick tube. My undereducated assumption would be that the valve seals are gone in this cylinder (or worse, cracked head). Any tests you may know of to see if it is just the seals or hole in the piston? Any other suggestions?
That's what I was afraid of. It sounds like I need to do a complete engine swap. There goes the pocketbook. Thank you HeyYou for the respond.
