02 ram 1500 crank almost starts
Old Aug 31, 2024 | 04:19 PM
Dodge-Freak's Avatar
Dodge-Freak
Default 02 ram 1500 crank almost starts
long story short, 2 days ago i test drove my truck after getting rebuilt from the frame up and a trans rebuild, when test driving it kept stalling, hmm weird, must be a mixture of old gas and a known vacuum leak, fix the leak but don’t do anything about the old gas, it needed a new belt and tensioner, put it on, starts fine and runs good as expected, idles and revs up no issues, don’t start it for 2 days and today i go to start it to test it again, and it won’t start, at all.. when i turn the key to prime the fuel pump a few times and try to start it, it’ll fire off for half a second then back to cranking… crazy
Old Sep 1, 2024 | 01:11 AM
master tech's Avatar
master tech
Site Moderator & Tech
Did you have the engine and transmission rebuild? You could have a bad ignition switch. I would check the wires from the PDC going down to the starter first.
Old Sep 1, 2024 | 08:03 PM
Dodge-Freak
nope just the trans, i was gonna get the engine rebuilt but had no help, i just rewired my cam sensor bc the wires were all exposed and wet with a mysterious liquid
Old Sep 1, 2024 | 11:28 PM
master tech
Did that solve your problem?
Old Sep 2, 2024 | 02:13 PM
Dodge-Freak
haven’t checked yet, i’m hoping it did, but i’m worried it jumped timing, i have not the slightest idea on how to retime it
