P0122 and P0222 anyone?
Old Sep 23, 2024 | 01:29 PM
Whitetrash04derdge's Avatar
Whitetrash04derdge
Do not run jumper wires to ground for TCC and O/D. You don't want those solenoids engaged all the time. That would make the truck undriveable.
You're right I read the previous post to fast or misunderstood. Ill make sure the proper pins have power and ground
Old Sep 24, 2024 | 07:30 PM
Whitetrash04derdge
Originally Posted by Prismatic
Make sure you still have your 5v reference circuits, use your multimeter set to 12v dc, don't use a test light. Check pins 2 and 3 to ground. If no power, check pins 2 and 3 for continuity to ground.
Granted, I don't know if those are supplied power KOEO, but I would assume so.
Pins 2 and 3 have 5 volts as they should. They do not test for continuity but pins 4 and 6 test good for continuity to ground. I don't know how to read the picture you sent because no legend but ill look it up if I can.
Old Mar 18, 2025 | 11:02 PM
Whitetrash04derdge
Figured it out guys after replacing the pcm everything works fine. Not sure what caused the problem to begin with but im guessing to much heat coming off the headers.
Hopefully this helps someone down the road i would be happy to explain everything i did that lead me to pcm
