Can’t find the right answer 04 ram 1500
Old Nov 21, 2024 | 07:26 PM
mjdwyer88's Avatar
mjdwyer88
Default Can’t find the right answer 04 ram 1500
I have a 04 Ram 1500 with a 5.7 Hemi. It has me stomped as to what is going on with it. After changing out the spark plugs it would not start and I figured out that the fuel pump needed to be replaced. After replacing it the truck fired up and ran better than ever. The next time I went to start it all I got was cranks until it eventually started but stalled out just a few minutes later. I can manage to get it to idle for about 5 minutes before it cuts off. It is not ahowing any codes.
Old Nov 21, 2024 | 10:00 PM
Does it stumble and die, or is it like someone just switched off the key?
Old Nov 22, 2024 | 05:55 AM
mjdwyer88's Avatar
mjdwyer88
more like it’s been turned off. It stumbles for maybe a second if it’s idling. When driving it just turns off.
Old Nov 22, 2024 | 09:29 AM
I would be tempted to put a fuel pressure gauge on it, and let it sit and idle till it dies.... See what fuel pressure is doing right BEFORE it dies.
