Paddle shifters
Old Mar 26, 2025 | 08:31 PM
3rdgenlaramie's Avatar
3rdgenlaramie
Default Paddle shifters
I have a 2004 ram 1500 Laramie it’s a 4wd 4d with a 5.7 hemi and I was wondering if anyone has any information on who makes a good paddle shifter kit that doesn’t need flashed to work is just wire it up and go kinda thing for under $1000 so far I haven’t found any reliable places to buy a kit like that from
Old Mar 26, 2025 | 09:27 PM
I see one for the cummins trucks..... also for various jeep models. (as it was an option on some, and can be adapted to others) Some are fairly cheap, but, that assumes that the functionality is already available in the programming... Which isn't the case for the full size trucks.... It IS a Truck after all, not a sports car. There are videos on youtube for the cummins install, supposedly a kit by suncoast, but, I can't find the product itself on their site.
Old Mar 26, 2025 | 10:27 PM
dodgetruck2's Avatar
dodgetruck2
This I would assume only works on 68RFE trucks which already have manual gear shifting available? The 48RE is still hydraulic 1-3?
The 545RFE in theory should be capable of it but manual shifting was never an option that I'm aware, not until they renamed it the 65/66RFE anyway, which is more or less that same transmission, newer TCM and controls, 66 it built heavier
Old Mar 26, 2025 | 11:05 PM
Prismatic's Avatar
Prismatic
Years ago you could get the PCS TCM2000 kit with a 545rfe harness and paddle shifters but there's really not much support for the 545rfes anymore.
Old Mar 27, 2025 | 09:41 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Manual shifting was available on the 545RFE starting in 2009. Paddles were never an available option nor have I ever seen a kit that would work with a 3G steering wheel. Real question is why? This sounds like it's a big heavy stock truck....not exactly a manual shifting speed demon.
