PCM Swap?
Old Apr 28, 2025 | 02:54 PM
Dhalas818's Avatar
Dhalas818
Default PCM Swap?
Can a switch out a possible faulty PCM with one from the same model year and same part number without having to program a vin # and milage?
Old Apr 28, 2025 | 04:11 PM
It will probably run the engine, but several systems will not work, ABS, and Air Bags being a couple. There are others that won't work as well.
Old Apr 29, 2025 | 09:15 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Depends on the year & options. If SKIM equipped not only will you get VIN error codes but you'll also lock the PCM after a few tries.
