Please help 2007 ram no crank
Old Jan 31, 2026 | 06:31 PM
LDD76's Avatar
LDD76
Default Please help 2007 ram no crank
I stopped at Napa to have battery checked (battery good), went to start and would barely crank, tried again and barely cranked, went to try third time and nothing, so put on new starter and still no power to starter, I checked all fuses, wires in back of TIPM, everything looks good. I can jump across the solenoid and engine cranks but won’t start, so it’s like whatever is keeping starter from working also won’t let the engine fire (fuel pump is working) when I checked old starter would not turn at all did it short out something in tipm or am I missing something
Old Feb 2, 2026 | 06:47 PM
Alex Medeiros's Avatar
Alex Medeiros
Check your main grounds. Sometimes just a ground wire coming loose can cause a power issue.
