Prndl
Old Feb 21, 2026 | 08:49 AM
PJD's Avatar
PJD
Default Prndl
after code 2509 NO CRANK anymore and, no new codes.... "SPNDL indicator not showing on dashboard".....how to proceed diagnosing and hopefully fix it. (2007.5 ram 2500, SLT, 2wd., 6 automatic)
Old Feb 21, 2026 | 09:06 AM
p2509 Code - ECM/PCM Power Input Signal Intermittent
Check your fuses, battery connections, etc.
Old Feb 22, 2026 | 07:53 AM
PJD's Avatar
PJD
batteries replaced & all grounds cleaned and checked for voltage drop/ the PRNDL is needed for crank authorization....how to diagnose / fix PRNDL ?
Old Feb 22, 2026 | 09:15 AM
Are you still getting the code?
Old Feb 22, 2026 | 10:38 AM
PJD's Avatar
PJD
code was deleted, now no crank/no start/no codes but 12v+ and ground ok on diagnostic module,
replaced transmission range sensor module again no change,
Old Feb 22, 2026 | 11:23 AM
Usually, if it's a range sensor problem, ALL the gears light up, and it sets a code, if you are not getting a display at all, that's likely something else. Will your scanner tell you what gear the PCM thinks it is in?
Old Feb 22, 2026 | 01:55 PM
PJD's Avatar
PJD
no indication of shifter position on scan tool
Old Feb 22, 2026 | 04:39 PM
You need a service manual for your truck. I think they are still published by Bishko, should be able to get a downloadable version from them for relatively cheap.
Old Feb 23, 2026 | 04:52 PM
PJD's Avatar
PJD
Nice try !
