Xenon Headlight Bulbs
Old Jan 31, 2006 | 11:02 PM
2002ramman's Avatar
2002ramman
Default Xenon Headlight Bulbs
has anyone added these to theit trucks and if so do they help at all?
Old Feb 1, 2006 | 02:37 AM
crcarch's Avatar
crcarch
Default RE: Xenon Headlight Bulbs
[sm=badidea.gif] I have tried HID bulbs and it wasn't a success. HID's only have one element, so goodbye high beams , hello annoying "Bulb Out" warning light that stays on constantly. Then there's the issue of the HID element not being oriented in the same position as the halogen filiment, so the light patterns all over the place. They light up the world and everybody else's face in the process. Oh, and one more thing, they don't always want to come on. Not fun to sit in the parking lot for several minutes waiting on the lights. I finally figured out if I turned them on first, then cranked the motor that they'd work. Did I mention these were made by Philips and cost $500!
In case you haven't figured it out yet, my recommendation would be a big fat NO!
If you're looking to pump up the light, there's a good article in the newest edition of Mopar Action about high-tech lighting. They referred to this site www.danielsternlighting.com. It's loaded with info. and worth checking out. Very enlightening.
Old Feb 1, 2006 | 02:43 AM
bmxox's Avatar
bmxox
^^ I dont know what kit you have but I know several people that have put aftermarket HID kits in their car and have had nothing but success with them. And you can get low and high beam HID. All it takes is a little aiming to get them to shine where you want, thats why the housings have adjustments on them.
Old Feb 1, 2006 | 03:00 AM
crcarch's Avatar
crcarch
ORIGINAL: bmxox
My friend had a two bulb system for hi/low in his car (Passat) and it wasn't a problem, either. It used HID's to replace his stock projector bulb low beam and retained the halogen for high (Just like the A6 Audi, which is similar). It worked great so that's why I jumped on it for the Ram, not thinking about the one-bulb issue. Maybe someone makes an assembly that has two elements for the RAM.
As to adjustments....when you turn a spotlight into a floodlight, even if you could adjust it 30 degrees, your still blinding everyone in front of you. Stock RAM reflectors just aren't compatible.
Old Feb 1, 2006 | 05:42 AM
silvernightmare's Avatar
silvernightmare
I have sylvania silver stars and they are bright white and last for a long time.
Old Feb 1, 2006 | 05:47 AM
4xfreak's Avatar
4xfreak
I've got Nokya Arcitc White bulbs that I bought off ebay. Paid $50 for headlight and fogs. Makes the road ahead alot clearer, overall well worth the money.
Old Feb 1, 2006 | 12:32 PM
crcarch's Avatar
crcarch
ORIGINAL: silvernightmare
These are what I ended up using, too. They work well.
Old Feb 1, 2006 | 03:27 PM
elevatedmind's Avatar
elevatedmind
ORIGINAL: 4xfreak
I have Nokya Cosmic White on my headlights and fogs, huge difference. Just make sure you upgrade your wires, when you have high intensity bulbs the OEM wires might melt and/or not send the right amount of power to the bulbs
Old Feb 1, 2006 | 07:15 PM
2002ramman's Avatar
2002ramman
alright i think i will go ahead and throw some of the silver star ones in my ram and see what she dose. i will post results soon!
