06 Hemi throttle Lag
Old Mar 5, 2006 | 11:12 PM
Hemimadman06's Avatar
Hemimadman06
Default 06 Hemi throttle Lag
Has anyone encountered on the 06 hemi that when u get on it it lags a bit before it takes off, almost the same thing as turbo lag????
Old Mar 5, 2006 | 11:44 PM
sandiegohemi's Avatar
sandiegohemi
Default RE: 06 Hemi throttle Lag
It does it on an 04 as well. It is nothing unique to an 06.
Old Mar 6, 2006 | 12:17 AM
silvernightmare's Avatar
silvernightmare
I have an 04 Hemi and I have not experienced any lag.
Old Mar 6, 2006 | 12:48 AM
sandiegohemi
I think "lag" is the incorrect term. I think he is referring to the time between flooring on the gas pedal and the rpm's shooting up. There were some other posts on here and someone said it is due the throttle control system. I have not noticed it since adding an exhaust, CAI, and Superchips.
Old Mar 6, 2006 | 09:14 PM
Nick23's Avatar
Nick23
I think he really means the torque management!
Old Mar 6, 2006 | 09:19 PM
whoosh's Avatar
whoosh
Could it be part of the MDS?
Old Mar 6, 2006 | 09:20 PM
Nick23's Avatar
Nick23
when i was using regular gas, i noticed that lag alot more than when i started using a higher octane fuel like supreme. other than that, try pushing the throttle harder at first till the power hits then let off a little. may need some gettin used to. it works for me anyways!
Old Mar 7, 2006 | 12:29 AM
IrishBull's Avatar
IrishBull
It's the other four cylinders waiting to light off.
Old Mar 7, 2006 | 12:37 AM
Mystro's Avatar
Mystro
No lag here. Just the opposite for me. I have to be real light on the pedal.
Old Mar 7, 2006 | 12:44 AM
CarGuyOhio's Avatar
CarGuyOhio
Off the line there is no lag in my truck. But if you are cruising, whether highway or city streets speeds and stomp on it the truck does take a split second to come alive. It definatly could be more responsive in that area, but I am sure it is built in for a reason.
One thing to note, when I installed my Jet Module some of this has disappeared. Reason, when driving under 40 my truck never kicks into OD. So when I am under 40 and hit the gas I get much better response. The cost, a little lower gas milage, but that is only if I cruise at less than 40.
