Dealer BS
Old Mar 9, 2006 | 08:11 PM
sandiegohemi's Avatar
sandiegohemi
Default Dealer BS
I am at 28,000 and planned on changing the sparks plugs on the next visit. So, I call the dealer where I usually go for service. They quote $455 to do the spark plugs (high in my opinion, but whatever). Then he says they recommend cleaning the throttle body every 15,000 miles (carbon build up) - $100. On top that, they say I need to change my transmission, differential, and transfer case fluids - approx $450 (I changed them at 18,000 so I'm good until 48,000 miles), but he said they need to be changed every 15,000 miles. To top it all off, he says I should flush the brakes and power steering. The total bill for everything would have come to $1,200!
So, I call another Dodge dealer closer to my house and he says, "$250 parts and labor for the spark plugs, $100 for the throttle body cleaning, your transmission, transfer case and differential fluid is good for 30,000 mile intervals, and you don't flush the brakes and power steering until you hit 60,000 miles. So, Dealer A wanted $1,200 to do things I don't need, while Dealer B quoted me $398 for spark plug change, oil change, and throttle body cleaning.
Just thought I'd share this with those of you approaching the 30,000 mile service.
Old Mar 9, 2006 | 08:27 PM
Drew's Avatar
Drew
Default RE: Dealer BS
do it yourself for the cost of parts and walk away with a smug grin on your face knowing you did it right the first time
got 28k on my truck and has seen the stealer once to replace weather stripping at no cost to me
Old Mar 9, 2006 | 08:51 PM
WingViper's Avatar
WingViper
Hell yea man, do it yourself! At least the spark plugs and oil. Forget the TB, find another shop to do the diff and tranny, cause that can be a pain, but they'll be cheaper.
Old Mar 9, 2006 | 09:59 PM
sandiegohemi
The thing about the tranny, diff, and transfer case is that I just had them all changed 10,000 miles ago. I can still go another 20,000 miles. The guy told the only time you need to change it sooner is if you do a lot of towing (which I don't) or offroad it a lot (which I don't). They were just trying to make a buck (or a few extra bucks in this case).
Old Mar 9, 2006 | 10:03 PM
rob[GL]'s Avatar
rob[GL]
$250USD to change sparkplugs? That sounds like a LOT dude... WTF you guys get ripped...
Old Mar 9, 2006 | 10:16 PM
sandiegohemi
16 spark plugs
Old Mar 10, 2006 | 01:21 AM
rob[GL]'s Avatar
rob[GL]
http://www.rpmoutlet.com/ngkinfoi.htm
Even for NGK5306, at $1.99/each, that's $32 for replacement plugs... Which means they want to charge you $218USD to do the labour? What are the labour rates in USA? Still sounds like way too much money.
Maybe that's why **** is so differnet in Canada... I pay $45,000CAD up front of the truck, and getting **** done here is cheap.
Old Mar 10, 2006 | 01:35 AM
HemiMan4451's Avatar
HemiMan4451
ORIGINAL: rob[GL]
45,000CAD, whats that like $100 American? =P
labor kills here.
Old Mar 10, 2006 | 01:39 AM
whoosh's Avatar
whoosh
16 plugs? Hemi's have two sparklers per cylinder?
Old Mar 10, 2006 | 01:49 AM
05slthemi's Avatar
05slthemi
Yes 2 per cylinder. From what I've read, you have to the remove the master cylinder and power booster to change plugs. More than likely dont really need to. Just another way for the stealership to make money.
