biggest size tires?
Old Mar 25, 2006 | 02:37 AM
cableguy1224's Avatar
cableguy1224
Default RE: biggest size tires?
I forgot to say a stock NO LIFT just bigger tires and maybe wheels
Thank you guys
Old Mar 25, 2006 | 10:40 AM
osteodoc08's Avatar
osteodoc08
ORIGINAL: cableguy1224
Hey Grayghost, DO you or any one on here have a picture of a STOCK ram QC with some 265/70/17 tires, I have the stock 245/70/17s and I want to see what it looks like a tad bigger
Thank you
Check out my pics and you'll see the stockers on my truck in the 265/70/R17 size.
Old Mar 25, 2006 | 12:30 PM
cableguy1224
Thank you very much for the fast reply osteodoc08, Good looking truck man! Yeah there really not much bigger looking then my stock 245/70/17s on my os 05 Ram, I will post some pictures of my new ram soon here too, I wonder why dodge went to the 245 instead of the 265 on my 05??
Thanks again
Old Mar 25, 2006 | 12:35 PM
cableguy1224
Hey GreyGhost,
Do your 285s rub AT ALL from turning or any type of bumps or humps, I like the 285/70/17 look with the front end leveled though
Thanks
Old Mar 25, 2006 | 12:50 PM
GreyGhost's Avatar
GreyGhost
Cableguy, The 285's are no problem at all on my truck. No rubbing at full turn (even on the front, not leveled), much better handling with the wider tread. I put the AT's on mine as well so the traction has vastly improved! Take a look at my gallery. I plan on putting better pics up soon when the weather clears up and I get a chance.
Old Mar 25, 2006 | 01:17 PM
cableguy1224
Yeah I really like it ghost, Did it messyour speedo up and make it off a bit with the 285?
Yeah I have been adding lots of fun stuff to my 05 Ram so i will get the pics up soon too
Old Mar 25, 2006 | 01:36 PM
osteodoc08's Avatar
osteodoc08
Thanks again
Thank you. There isn't that much of a difference. It is about a 1" taller and 1" wider. If you need new tires, perhaps you should look at the 285/70/R17 as mentioned. Don't forget that you'll lose some low end because of the effective gearing change and your speedo will be off by a bit. You can go to tire rack and play with the sizing to see what the difference in height/width for a given tire.
Old Mar 25, 2006 | 01:41 PM
Mystro's Avatar
Mystro
My 2006 Ram 2500HD 4x4 came with BF Goodrich on/off road 265/70/17 E rated tires. They are 31.6" tall.
The PowerWagon comes with BF Goodrich on/off road 285/70/17 D rated tires. They are 32.7" tall. Both really get the job done on and off the road
[IMG]local://upfiles/30292/E3E196E8F6EA4CBDBE18103E1274A661.jpg[/IMG]
Old Mar 25, 2006 | 01:52 PM
cableguy1224
thank you very much guys, Yeah I dont need tires I just want them, The stocks look WAY TO SMALL, I really like this site lots of GREAT info and GREAT people toooooo
Old Mar 25, 2006 | 05:23 PM
GreyGhost's Avatar
GreyGhost
As far as the speedo change with the bigger tires, I'm sure there's a small change but it's nothing noticeable to be honest with you. You can always take it in to the dealership and have them reprogram. Osteodoc brought up another good thing to be concerned with also (gearing). I hear alot of people complaining about lack of low end on their trucks. I have the 5 speed manual that makes up for alot of the lost power though so that's not really a problem either. Depending on what gears your truck has (3:55, 3:92, 4:10 etc..) you may or may not notice any change.
I wouldn't think twice about the tire upgrade, it's definitely made my truck better! Go for it!
