Torn between 2 trucks
Old Apr 19, 2006 | 11:53 PM
jhalfhill's Avatar
jhalfhill
Default RE: Torn between 2 trucks
ORIGINAL: ibanezta
what is it about the hemi that you don't want? it gets better mileage than the CTD, and out here in the cali bay area, diesel is a couple cents over premium unleaded. so unless you're towing all the damn time, id just get it with the hemi. it'd be better off road any ways with the hemi. otherwise, i wouldnt bother with the power wagon if you want a CTD.
1. I'm a mechanical engineer and I LOVE to tinker with diesels.
2. Contrary to what you say the CTD does get a hell of a lot better fuel efficiency than the Hemi.
3. 300,000 to overhaul
4. I want the mean looks of the jacked up PowerWagon with the sound and smell of burnt diesel.
I'm sure I can list a bunch more reasons if i sat here and thought for a sec. But if the only changes needed involve relocating the winch and putting in lightly heavier shocks then I really don't see why this would be so difficult to do. Its not like cutting my articulation a few degrees shorter is gonna effect me anyway. Like I said i'm in a year i'll have my degree in mechanical engineering and I love projects.
Old Apr 19, 2006 | 11:58 PM
jhalfhill's Avatar
jhalfhill
OK i'm changing my mind on the power wagon to CTD conversion. I think it would be much easier for me to buy a quad cab CTD and convert it to a powerwagon minus the winch. all i'd really have to do is re-badge, lift, new shocks, new sway bar. DONE
yea yea it wouldnt have th granny gear but 1st gear in a standard cummins 6 speed is low enough
Old Apr 21, 2006 | 05:35 PM
dakotaquadsport's Avatar
dakotaquadsport
ORIGINAL: jhalfhill
but the transmission in the powerwagons would work with the CTD?
As far as Automatics go the 5.7's use the 545RFE in the Powerwagon, IIRC CTD's use the 48RE. Also I'm pretty certain with the electronic throttle control when you throw it in 4 low it's programmed do desensitize the throttle, as like how it does in the HEMI Jeeps. 6 speed manual would work. I'm waiting to see how the 6 speed ASIN Auto plays out, and if it's going to make it down from the 3500 Chassis Cabs to the 2500's.
