removing Rain-X
Old Apr 19, 2006 | 01:44 AM
derwood's Avatar
derwood
Default removing Rain-X
Put Rain-X on my windshield and hate the way it works[sm=smiley21.gif]. Anyone know how to remove it?
Old Apr 19, 2006 | 01:53 AM
05_FL_RAM's Avatar
05_FL_RAM
Default RE: removing Rain-X
you prolly tried using your wipers didn't you?
the idea is to look through the little dropplets sitting on the window...not right at them.
BTW.....vinegar.
Old Apr 19, 2006 | 12:48 PM
Klute's Avatar
Klute
it will wear off
Old Apr 19, 2006 | 12:55 PM
hillac's Avatar
hillac
Use glass cleaner and it will come off. I belive that Rain-X makes a glasswipe / precleaner that will also work.
2003 Ram 2500HD
5.7L Hemi 4x4
Quad Cab
Old Apr 20, 2006 | 01:56 AM
mill500's Avatar
mill500
I did the same thing some time ago to one of my vehicles and all the stuff did was make a mess of the windshield during a rain. I agree with the vinegar/water. If that doesn't work, try normal alcohol, and rinse.
Old Apr 20, 2006 | 02:14 AM
dRam2500CT's Avatar
dRam2500CT
All I use on my windsheild is Glass Plus, works great. Tried RainX once, did not notice a difference.
Old Apr 20, 2006 | 03:21 AM
bevans's Avatar
bevans
If you do not apply Rain X correctly it will be a mess. Make sure to wipe off with a wet cloth right after application- I use this stuff on a 3 month basis. If anything it makes your wipers work better.
Old Apr 20, 2006 | 03:27 PM
cbrewer954's Avatar
cbrewer954
If you apply it correctly, the stuff works great. I always use it and the rain just slides right off. Works even better with the wipers.
Old Apr 20, 2006 | 03:55 PM
Horseapples's Avatar
Horseapples
I also have great luck with it,I add the rain-x washer fluid ,and it makes the initial application last longer, To remove use any amonia based window cleaner!
Old Apr 21, 2006 | 12:00 PM
derwood's Avatar
derwood
Thanks for all your input. Have always used Rain X and love the way it works on all the other windows. Helluva lot easier to clean them in the winter. Before I write off the product, I'll give it another try. Perhaps it was the applier and not the product!
