will a K&N intake and Flow master exhost give me better gas milage?
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
RE: will a K&N intake and Flow master exhost give me better gas milage?
2-3 MPG'S AND PERFORMANCE INCREASE.. CANT BEAT THAT... IT'S WORTH IT.. YOU MIGHT GET A LITTLE TRIGGER HAPPY WITH YOUR NEW MODS, BUT IF YOU CAN CONTROL YOURSELF YOU COULD SAVE SOME GAS... IF NOT YOU SURE WILL HAVE A WHOLE LOT OF FUN BURNING THE GAS YOU WERE TRYING TO SAVE
That depends on the dealer. My '01 was still under factory warranty and I had the posi go bad, so they replaced the whole rear end and I had a small lift. Some care, some don't.
You probably won't get any better mpg since you will like the rumble of the exhaust.
ORIGINAL: Mystro
Will these simple bolt-ons mess up your factory warranty?????
Exhaust won't. Say an air sensor or something else involved with the intake system goes bad, if you have a CAI, they might blame it on the CAI and not cover it.
