performance mods and capability
Old May 21, 2006 | 10:02 PM
nos4fuel's Avatar
nos4fuel
Default performance mods and capability
I'm curious to know if mods such as intake/exhaust that yeild significant horsepower increases will also increase capability such as towing capacity. What do you guys think? I'd really like to know if they improve stuff like this, lemme know guys!
Old May 21, 2006 | 10:19 PM
AIR RAM's Avatar
AIR RAM
Default RE: performance mods and capability
ORIGINAL: nos4fuel
Anytime you increase the efficiancy of your engine you also increase its ability to make power... and towing capacity would also increase as long as your mods did NOT sacrifice low end torque.
SPEED SAFE, AIR RAM
Old May 21, 2006 | 10:22 PM
nos4fuel's Avatar
nos4fuel
ORIGINAL: AIR RAM
ORIGINAL: nos4fuel
SPEED SAFE, AIR RAM
what kinds of mods would negatively affect low end torque?
Old May 21, 2006 | 10:40 PM
20brewcity02's Avatar
20brewcity02
reducing back pressure
Old May 21, 2006 | 10:53 PM
nos4fuel's Avatar
nos4fuel
besides running open headers, what else would reduce back pressure?
Old May 21, 2006 | 11:42 PM
AIR RAM's Avatar
AIR RAM
Reducing BACK PRESSURE has NOTHING to do with torque or HP... You want to ELIMINATE "back pressure" completely! For some reason people still think engines need back pressure. Backpressure has NO PLACE in the performance vocabulary.
Your exhaust needs to promote VELOCITY. If you go too large you lose velocity, if you go to small you gain back pressure if you go just right you get an exhaust system that MAKES the most power and torque.
So if you go too large you lose VELOCITY and this is why you lose low end torque... Backpressure and velocity are NOT one in the same. Back pressure is exactly what it says it is... a restriction.
But like mentioned above, chose the wrong exhaust and you could lose your low end torque.
SPEED SAFE, AIR RAM
Old May 22, 2006 | 12:18 AM
Ramman21's Avatar
Ramman21
As far as the exhaust goes, stick with something in the 2.5" out range give or take 1/4" for best results.
Old May 22, 2006 | 02:33 AM
AIR RAM's Avatar
AIR RAM
I personaly would go to a true single 3" ID with a High flow "Y" pipe, 3" CAT into a SI/SO high flow muff.
If you must have a dual exhaust system then go with dual 2.5" from the primarys into an "X" pipe into 2.25" true duals out the back.
SPEED SAFE, AIR RAM
Old May 23, 2006 | 04:11 PM
dan0617's Avatar
dan0617
What happens if I take a stock 2004 1500 hemi and just remove the resonator and replace it with a straight pipe? Will it be loud? Will it help the HP? Will it help the torque? If it isn't going to be real loud, I'd like to try it. Anyone else tried that? I can't afford a major exhaust mod right now.
Old May 24, 2006 | 10:26 PM
MR YOON's Avatar
MR YOON
ORIGINAL: AIR RAM
SPEED SAFE, AIR RAM
ditto. it's funny how much Nick and I go around telling people it's not the lack of backpressure that loses torque but in essence is the lost of exhaust scavenging aka exhaust velocity that loses performance and torque.. good one nick.
