TPS bad?
Old May 30, 2006 | 01:43 PM
xj2000's Avatar
xj2000
Default TPS bad?
2002 RAM 1500 WITH 4.7 When I am at idle at a stop my engine hunts. Rpm's go up and down from about 500 to 850. Also when at hwy speed it seems to jump out of final lockup. Rpms jump up and down about 200 rpms. Is this the Throttle Position Sensor or something else? Thanks
Old May 30, 2006 | 01:59 PM
HedleyLamarr's Avatar
HedleyLamarr
Default RE: TPS bad?
maybe because you didn't put the cover sheet on your TPS report?
Old May 30, 2006 | 02:05 PM
xj2000's Avatar
xj2000
Thats a good one! I love that Movie!
Old May 30, 2006 | 08:18 PM
srenken's Avatar
srenken
could be a vacuum leak.
Old May 30, 2006 | 08:20 PM
eatsleepdrivesc's Avatar
eatsleepdrivesc
thats what i thought when i saw tps that movie is the bomb
Old May 30, 2006 | 09:16 PM
Gone Fishin's Avatar
Gone Fishin
Chances are, that if the TPS is acting up, you would throw a code. I'd be more inclined to think that the throttle body is in need of cleaning, or possibly a general tune-up. Plugs, possibly wires, injector cleaner, throttle body cleaning. Start here first, if it continues, there may actually be a problem.
Old May 31, 2006 | 11:38 AM
xj2000's Avatar
xj2000
It was the TPS. $80 dollars later and about 10 min work and everything back to normal. No check engine light during this problem!
