Gears...
Old Jul 5, 2006 | 06:39 PM
frogslinger's Avatar
frogslinger
Default Gears...
Where can i find the data plate telling me what axle and gear ratio is in my truck?... I know on the 04 it was in the glove box but i cannot find it on the 06.
Old Jul 5, 2006 | 06:52 PM
eatsleepdrivesc's Avatar
eatsleepdrivesc
Default RE: Gears...
if you give me the last eight of the vin and the approx current mileage i can run a report to see what it has in it? just pm me the info
Old Jul 5, 2006 | 08:59 PM
New2Durango's Avatar
New2Durango
Did you check the sticker from the window??
Old Jul 6, 2006 | 12:22 AM
frogslinger
I already know I have 3.92 gears... I want to know what axle I have, which is located on the data plate (along with other good info like paint codes) which is why I asked where the data plate is.
Thanks.
Old Jul 6, 2006 | 12:30 AM
AIR RAM's Avatar
AIR RAM
ORIGINAL: frogslinger
Thanks.
If you have a 2x4 then you have the 9.25 rear end
SPEED SAFE, AIR RAM
Old Jul 6, 2006 | 01:42 AM
frogslinger
thanks... it is 4x4 but I am sure it is the same
Old Jul 6, 2006 | 02:20 AM
AIR RAM's Avatar
AIR RAM
I think you have the 9.25 rear but Im not sure on the front... I do know if you change your gears on a 4x4 you need to do both front and back... just in case you already did not know that.
SPEED SAFE, AIR RAM
Old Jul 6, 2006 | 03:14 AM
frogslinger
I did know that actually... dreading it too... hoping the 3.92 will be enough to turn over those 33s in the mud....
Old Jul 6, 2006 | 11:34 AM
kenihemi's Avatar
kenihemi
Yeah, its a 9.25 rear. Not sure about the 06, but the 03-05's have the ifs 8" in the front.
In the mud, your 3.92 should be OK, but I suggest 4.56.
