I have a transmission ? Please Help
Old Jul 7, 2006 | 06:47 PM
Nicky B's Avatar
Nicky B
Default I have a transmission ? Please Help
I own a 03 RC Hemi Ram it has just 35,000miles on it. I bought it from a 54 year old man so I know it has not be beatin on. But the thing is when I move through the gears like from Park to Reverse I hear alittle noise then a click! But somtimes when I push the brake pedal all the way down the sound is barly there or no there at all. I only hear the sound going from P to R or P to D or R to D. Now the question is should I go to shop and ask them to go through my transmission with a fine tooth coam and see what the problem is. I get my car through a check up 2months ago but I don't think they did a transmission flush should i tell them to do that would that fix the noise or if its a problem fix it. And I plan on some descent modd's in August like headers, cam's, CAI, 4.56gears and being an 03 beehive valvesprings just want my truck to be in good shape so I don't need a new trans after all my work on the truck is done.
Old Jul 7, 2006 | 09:37 PM
mazz's Avatar
mazz
Default RE: I have a transmission ? Please Help
I would check the universal joints on the drive shaft and see if they need to be replaced.
Old Jul 8, 2006 | 01:38 AM
eatsleepdrivesc's Avatar
eatsleepdrivesc
are you on a incline when this happens? or are you on flat ground?
Old Jul 8, 2006 | 02:42 AM
Nicky B's Avatar
Nicky B
ORIGINAL: eatsleepdrivesc
Happens on both. Its worse on a incline though noticed it at my gf house.
Old Jul 8, 2006 | 04:03 AM
eatsleepdrivesc
if it only happened on a incline then i would say it was normal but since it happens on both you probably should get your u-joints checked like mazz said. if thats not it then come back and let us know.
Old Jul 8, 2006 | 04:46 PM
Nicky B's Avatar
Nicky B
Going to have the truck checked out on Monday. But won't be to get back to you guys untill I get back from texas on the 17th. Thanks for your help guys.
Old Jul 8, 2006 | 06:13 PM
Nicky B's Avatar
Nicky B
And if the universal joints need to be replaced how long would that take?
Old Jul 8, 2006 | 09:14 PM
Stroker's Avatar
Stroker
For some one who know what their doing about 30 min or so I would guess but I have never done this to a Dodge.
Old Jul 8, 2006 | 09:34 PM
Nicky B's Avatar
Nicky B
ORIGINAL: Stroker
Well the shop would need to order the part or parts right?
Old Jul 10, 2006 | 02:22 AM
Nicky B's Avatar
Nicky B
A weird thing happened today I went from Park to Reverse but he didn't go into Reverse it stayed in Park but ther I went to park then reverse again and then it went into reverse. Is this a sign of a serious problem?
