Just had axles and transfer case serviced now trouble
Old Jul 9, 2006 | 08:50 PM
MY D8ONA's Avatar
MY D8ONA
Default Just had axles and transfer case serviced now trouble
I just had the dealer do the whole driveline service now when I shift into 4hi back into 2wd the stick shift want to slide back and forth too easily between N-2wd-4hi. It doesn't seem to be locking in to 2wd firmly like it did before sevice.? Any thoughts?
Old Jul 9, 2006 | 10:22 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: Just had axles and transfer case serviced now trouble
Yes,
Take it back and tell them to make it right, and ask what they did to make it wrong in the first place.
Old Jul 10, 2006 | 11:48 PM
MY D8ONA's Avatar
MY D8ONA
Default RE: Just had axles and transfer case serviced now trouble **** Update*****
Took it back to the dealer. He says transfer case needs rebuilt. It wont even stay in 4wd coming down the dirt driveway. It just slides onto 2wd. What happened? I told the dealer I put it in 4wd to check to see if everything was working. He says 4wd on pavement is a no-no. But 25 mph in s straight line? The transfer case should not be that sensitive. Thank you warranty. He said one they rebuild would be better than one of the shelf?
Old Jul 11, 2006 | 12:55 AM
Monkeyman's Avatar
Monkeyman
My owners manual ('03) says 4wd high is good up to 55mph on any surface. You might want to show the dealer your owners manual. Maybe even contact DC directly if the dealer wants to be a *****.
