custom sub box, UPDATED
Old Jul 11, 2006 | 04:53 PM
1swtbrz's Avatar
1swtbrz
Default RE: custom sub box
thanks air ram
silvernightmare, it sounded better when it was in the trunk of my car but it still sounds pretty damn good. one reason for that might be that in the truck its hooked up to the stock deck where as in the car it had an aftermarket deck so i could tune it better
Old Jul 11, 2006 | 05:02 PM
Stroker's Avatar
Stroker
Did you just use self tapping screw to bolt that thing down or what? I think I can do that but was woundering just how you bolted t down. Thanks, And it looks great.
Old Jul 11, 2006 | 05:18 PM
1swtbrz's Avatar
1swtbrz
well you can see i used the bolts that the seats are held down with(you will need longer ones which i happened to have) and then i actually drilled holes along the front for the screws but i dont see why you couldnt use self tapping as long as they are long enough
Old Jul 11, 2006 | 07:51 PM
Stroker's Avatar
Stroker
Ok 1 more question I didn't notice the first time. How did you stretch that Vinyl? Did you use anything on it (water, heat, baby oil) or just pull like hell? Either way I'm even more impressed once I noticed that.
Old Jul 12, 2006 | 05:23 AM
1swtbrz's Avatar
1swtbrz
ORIGINAL: Stroker
well, i live in phoenix, az and i did it in the middle of the day while in the sun and the temp was around 108 degrees. the vinyl got pretty hot and we steched and glued and stapled the material to the wood. it took about 20 minutes to complete the vinyl wraping
Old Jul 12, 2006 | 09:41 PM
Stroker's Avatar
Stroker
Cool Thanks. Now I just need to go shopping.
Old Jul 13, 2006 | 03:12 AM
MasterClean's Avatar
MasterClean
How hard was it to pull up the carpet to get everything wired up? Im tryin to find a good deal on 2 10s and doin the same thing.
Old Jul 13, 2006 | 03:45 AM
1swtbrz's Avatar
1swtbrz
i mounted the amp under the front seat so basically you have to run the power wire through the firewall then if you take the door trim off you have plenty of room to run the wire. just had to cut a an "x" in the carpet to feed the wire to the amp. you really dont have to pull up the carpet, just the plastic trim and then feed the wires under the carpet to where ever they are going. it was all the same as far as the other wires
Old Jul 13, 2006 | 03:51 PM
MasterClean
Stupid question, but how did u get the door trim off and on? I was messin with it a little while ago but i cant figure it out.. and Im afraid i'm gonna break it.
Old Jul 14, 2006 | 04:00 AM
1swtbrz's Avatar
1swtbrz
just use a flathead screwdriver and pry it up. its just a coupls clips on each piece. if your worried about it breaking just pry it up a little and you should be able to see where the clips are and just pry right where they are
