Tow hitch drop?
Old Jul 11, 2006 | 03:06 AM
gordo24fan's Avatar
gordo24fan
Default Tow hitch drop?
Was curious as to what type of drop you should use on the hitch for a 2006 2WD Ram 1500? I was thinking 2 inch, but the truck sure looks high for stock.
Old Jul 11, 2006 | 03:25 AM
BigSkyDodge's Avatar
BigSkyDodge
Default RE: Tow hitch drop?
Yeah, mine sits high in the back too. It's normal after reading posts on here about guys wanting to level the look and what not. Difficult to tell you what drop to use. I have three different lengths of drop for three different trailers. Just depends. Maybe someone more qualified can put measureing instructions on here for you or point you in the right direction. But, a 2 inch drop one might get you by just fine for most applications.
Old Jul 11, 2006 | 03:44 AM
kvsmith2004's Avatar
kvsmith2004
I have a 2" drop on mine and I have a little 4X6 trailer with 8" wheels that sits level when hooked up to the truck, I thought that the trailer would sit higher in the front but its just fine. I have another small trailer and when its hooked up it sits very high in the front, I guess it all depends on the trailer.
Old Jul 11, 2006 | 03:53 AM
gordo24fan's Avatar
gordo24fan
Thanks guys. got a friend that has a 3" drop he is going to give me. Think I will buy a 2" one too. Couldn't hurt.
Old Jul 11, 2006 | 03:55 AM
g352nv's Avatar
g352nv
Where do you get the hitch to haul over 2k pounds? Aftermarket?
Old Jul 11, 2006 | 03:58 AM
cbrewer954's Avatar
cbrewer954
I have a stock height 4x4 and I have a 5 inch drop to tow a standard sea-doo trailer. Get a class III hitch. They can handle most typical towing.
Old Jul 11, 2006 | 10:24 AM
motorhead426's Avatar
motorhead426
I've only towed 3 different car trailers and have not had to use a drop hitch. I just have your typical "Master Lock" hitch, and the trailers all looked pretty level. Just my $.02
Old Jul 11, 2006 | 10:33 AM
HemiBuell's Avatar
HemiBuell
I bought an adjustable height hitch. Need a 4" drop for the boat and a 2" drop for the car trailer.
Old Jul 11, 2006 | 11:25 AM
sumncguy's Avatar
sumncguy
I did alot of research after I bought my travel trailer (should have done it before). The answer to the question really depends on what you are towing and its weight. From what Ive read, the tongue weight should be 10 to 15 percent of the total weight that you are pulling and, the rear end of the truck should squat no more then an inch, and the front end of the truck should not rise any more then an inch. basically keeping everything nice and level. Again, this is generally speaking ... I found that there is a science, for lack of a better word, to this stuff ...
Old Jul 11, 2006 | 11:59 AM
watch3612's Avatar
watch3612
I'll make my first post here worth something. I drive a '03 2wd 4.7L regular cab and I use a 1" rise with a 4500 lb trailer (loaded) and it couldn't sit any better. However, the same trailer applied to a 2500 Chevy requires a 1" drop hitch (or the 1" rise flipped over). In both cases, the trucks don't sag and the trailer is flat. But like sumncguy said, it depends tongue weight and the distance the truck's suspension deflects. You could try to solve it mathematically or just guess and check with different hitch combinations.
