wheel wigths
Old Jul 14, 2006 | 05:34 AM
frogslinger's Avatar
frogslinger
Default wheel wigths
What are the widths of the stock 17's on the 1500 and the Heavy duty trucks... I hear the 1500 is 7" but am not positive and want to know what is on the 2500 ... (reason is i saw some tires i want on a 2500 stock rim and wanted to know if they would fit.)
Old Jul 14, 2006 | 11:32 AM
eatsleepdrivesc's Avatar
eatsleepdrivesc
Default RE: wheel wigths
8 & 2500's wont fit 8 bolt lug pattern
Old Jul 14, 2006 | 10:48 PM
Stroker's Avatar
Stroker
You are correct on the 1500 being 7". Not sure about the 2500 but I would think it would be the same. If it is wider tha 7 I would be suprised if it was much bigger so it would fit just be a little taller.
Old Jul 14, 2006 | 10:59 PM
Stroker's Avatar
Stroker
You can go to Dodges site and check the specs. The 1500 Steel argent 17s are 7" wide. 2500 Steel argent 17s are 7.5" wide. All other 17s for both trucks are 8".
Old Jul 14, 2006 | 11:04 PM
frogslinger
thanks... if that is the case those tires i am looking at should fit fine.
