Whats the difference between an 06 1500 2WD and 4x4 for lifting?
Old Jul 30, 2006 | 07:17 PM
dacaur's Avatar
dacaur
Default Whats the difference between an 06 1500 2WD and 4x4 for lifting?
Can anyone tell me what is different about the 06 2WD that makes it so the 4x4 lifts wont fit? All I want is a 2-3" leveling kit for my 06 1500 2WD, but everything is 4x4 only... what gives?
Old Jul 30, 2006 | 07:22 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: Whats the difference between an 06 1500 2WD and 4x4 for lifting?
cheap way to do it would be go and look for some spring spacers, but i dont have experience with them so i couldnt tell how well they work. and my question to u is, why raise it to make it level when u could lower the rear and make it level? never could understand why guys with 2wd trucks wanna raise em [sm=dontgetit.gif]
Old Jul 30, 2006 | 09:17 PM
HazArD22083's Avatar
HazArD22083
cause its a truck.... raised trucks 2wheel drive or not still benefit from the added space. i have a two wheel drive because i had no reason for a 4 so i saved myself the money. its also quicker than the 4
[IMG]local://upfiles/38598/1B96CEAD564D46FCA32B42C62892618C.jpg[/IMG]
Old Jul 30, 2006 | 09:40 PM
The Burning Rom's Avatar
The Burning Rom
2wd has independant front suspension utilizing torsion bars. All you need to do to raise/lower the truck is adjust the torsion bars and have the vehicle realigned.
4wd has independant front suspension utilizing coil springs. For those, you either need a spring spacer kit or an entire new spring.
It's a change they made for 2006...(or was it 2005?) Either way, all the 1/2 tons from 02,03,04 (and maybe 05) had torsion bars regardless of 2wd/4wd configuration. Now only the 2wd 1/2 tons utilize torsion bars, which is the way it should be
Old Jul 30, 2006 | 11:32 PM
kvsmith2004's Avatar
kvsmith2004
I did not know a 2wd has torsion bars? I thought that only the 4wd have them.? So where are the torsion bars on a 2wd?
ORIGINAL: The Burning Rom
Old Jul 30, 2006 | 11:45 PM
tpowell3499's Avatar
tpowell3499
since when did 2wd have torsions and 4wd have coils.. Maybe you got them mixed up
Old Jul 31, 2006 | 12:01 AM
kvsmith2004
I am going off of what The Burning Rom said, as far as I know the 2WD's dont have torsion bars.
Old Aug 1, 2006 | 03:22 AM
dacaur's Avatar
dacaur
My 06 2WD Ram definitely doesn't have torsen bars, its a coil spring with a shock inside.
Old Aug 1, 2006 | 03:36 AM
coryk4's Avatar
coryk4
last time i looked my 05 swb 2wd has coils up front
Old Aug 1, 2006 | 04:03 AM
prerunner's Avatar
prerunner
i think Burning rom just had a typo. Just switch the 2wd/4wd when reading his post.
