A/C smell ?
Old Sep 4, 2006 | 03:01 PM
nash1970's Avatar
nash1970
Default A/C smell ?
It's been really hot so I started to use the A/C and I had this bad smell come out when first turning it on after it has been off . Has anyone else have a problem like this ?[:'(]
Old Sep 4, 2006 | 11:31 PM
dirtydodge02's Avatar
dirtydodge02
Default RE: A/C smell ?
Yeah, I've had that with mine too. Turns out that it's some kind of mildew. Check this out, worked for me.
https://dodgeforum.com/fb.asp?m=46477
Old Sep 5, 2006 | 05:55 AM
cbrewer954's Avatar
cbrewer954
another simple solution is to turn the a/c off before you shut the truck down. I always turn mine off about a block before I'm home. Leave the fan on though. It gives everything a chance to dry out and it won't mildew. It works pretty well.
Old Sep 5, 2006 | 04:07 PM
dirtydodge02
Yeah, that def. helps too. I do that in mine.
Old Sep 5, 2006 | 10:48 PM
SoCool's Avatar
SoCool
Try switching to fresh air mode once in a while. This helps eliminate odors as fresh air is drawn across the coil.
