Power Wire.....?
This was posted on another forum by another member. I know everyone has there own views on this which is cool just wanted to you guys to read this info
"Just want you to know that you can tell any doubters your power wire does work! We were at the dyno yesterday and for some unknown reason, a member we know from HTC was running really lean. The shop owner was actually concerned with how lean he was and had him stop on the dyno.
Scott had loaded a SC tune right before he jumped on the dyno, because he used another members programmer. So the other guy loaded to stock and loaded his SC on Scott's truck. As I was saying, he was super lean, so he pulled out his power wire to help richen things up.
It did richen up his numbers, still not where the techs wanted to see em, but a huge improvement over where it was at. Just to let you know, with the PW installed it immediately gave him an 11HP or so bump on the dyno. By fattening him up a little more, it gave him more power and brought him into a safer range.
The SC ended up locking onto his vehicle and they couldnt remove the SC tune from his truck. So we dont know if his truck was running lean before he even got there or what? So for all we know the SC tune may have whacked out his numbers since it was messed up. Luckily the owner of the SC, Lonnie from HTC, had his stock program loaded ok and could make his 400 mile trip home!
Sorry for the long post, but just wanted to say what I saw. I had a Power Wire before I got my SC. If I run into any problems like Scott did, you better believe I will be getting another PW, until a custom tune is out. Scott is a member on HTC so I can always have him contact you if you wanted to ask him about it Nick. Thanks again for your products man, plus your support and contact is always top notch".
