working on my brakes
Old Sep 29, 2006 | 11:55 PM
PyRoHAvoC's Avatar
PyRoHAvoC
Default working on my brakes
going to replace my rotors ... what size c clamp do i need to push back the caliper piston?
Old Sep 30, 2006 | 03:25 PM
PyRoHAvoC's Avatar
PyRoHAvoC
Default RE: working on my brakes
anyone?
Old Sep 30, 2006 | 09:14 PM
Gone Fishin's Avatar
Gone Fishin
Probably a 10 or 12".
Old Oct 1, 2006 | 10:46 PM
RUNOVRYOU's Avatar
RUNOVRYOU
I'm sure you're done already.... but next time, there's a much easier way to do that. take off the tire, and after that, find the opening in the top of the calliper. you will be able to use a long, sturdy flat head screw driver to wedge in there and pry back, pushing the pistons in. then unbolt the calliper and change your pads. last time i did the brakes on my '03, i think i might have taken 20 minutes total... using a floor jack and impact. good luck, hope you got it done alright!
Old Oct 2, 2006 | 01:56 AM
PyRoHAvoC's Avatar
PyRoHAvoC
ORIGINAL: RUNOVRYOU
i'll have to keep that in mind ... is it that simple for the rears too?
Old Oct 3, 2006 | 04:28 AM
arrowman's Avatar
arrowman
If you use the old brake pad to span the piston, an 8" C clamp is more than big enough.
Just be sure to go slow... and be sure not to pinch the boot.
Old Oct 13, 2006 | 04:31 AM
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
I haven't done it on my Ram yet, but if the piston has blind holes or slots in it, it needs to be rotated as it is pushed in, using a special tool.
Old Oct 13, 2006 | 05:51 AM
electrofuzz's Avatar
electrofuzz
If you leave the pad in, an 8" clamp is enough.
I just swapped my rotors for cross-drilled/slotted combos with ceramic pads.
