Changing Spark Plugs in 2004
Old Oct 2, 2006 | 02:10 AM
mbramble's Avatar
mbramble
Default Changing Spark Plugs in 2004
What's involved?? I haven't had a chance to take a close look but it looks awfully tight in there...
Thanks,
Mike
Old Oct 3, 2006 | 09:57 PM
cloud94725's Avatar
cloud94725
Default RE: Changing Spark Plugs in 2004
you have a coil on plug application and that means you dont have plug wires, and the last time i checked the coils cost like $55 and the plugs are a double platnuim plug so they are good for like 100,000 miles but the first 1 or 2 are easy the rest are not real easy but not to hard
Old Oct 5, 2006 | 12:07 AM
mbramble's Avatar
mbramble
Thanks very much for the info....
Mike
Old Oct 10, 2006 | 06:10 PM
1stRam's Avatar
1stRam
I just changed the plugs in mine yesterday. OEM's are NGK. I installed Champion Double Platnums. Tools needed are 10mm socket, ratchet w long extension and 5/8's deep socket. Also very helpful to have is a small vacuum hose to help in getting the new plugs started in the deep sockets.
I'm hoping my mpg will go back up now.
Old Nov 17, 2006 | 05:04 PM
03RamV6's Avatar
03RamV6
If you want a little more info...
It's not actually as bad as it looks, and is definitely a job you can tackle yourself, although each coil nut and plug takes a little bit different approach in my experience, and I needed a swivel, and a couple of different length extensions to do the job. If you have a good spark plug socket that will hold the spark plug, you can finger thread the plugs using it and a 6" extension.
To do the job to factory specs, you'll also need a torque wrench--a little 3/8" drive one that can handle 8-20 N-m and will fit in tight spaces is the way to go--some anti-seize compound for the spark plug threads, some silicone grease for the O-rings on the coils, and a source of compressed air. I really needed the compressed air. There was a bunch of dirt in the rear plug holes on both sides I wouldn't have wanted in my engine.
To get access to everything, remove the 10 mm bolt on either side of the resonator, release the four spring clips on the air filter box, release the the air filter box cover from the hooks on the engine side, then lift the front of the resonator to remove the plastic pin from the rubber grommet at the front of the resonator and work the resonator out of the rubber gasket that connects it to the throttle body. There is no clamp holding the resonator to the throttle body gasket, it just has a friction fit. Set the whole resonator/hose/air filter box top assembly aside. Stuff a clean shop rag in the throttle body gasket to keep dust from blowing into the throttle body. Remove the air filter and put it in a clean spot for the same reason. You may want to remove the left hand Allen screw on the resonator bracket and loosen the right hand screw so you can swivel the resonator bracket up out of the way to access the #1 coil nut with a socket.
Do one coil/plug at a time so there is no way you can drop a part in a cylinder!
Unplug the connector to the coil by pushing down on the release on the top of the plug and sliding them out of the coil.
After removing the 10 mm nut that holds each coil in place, use compressed air to blow out all the dust around the coil, then remove the coil (pull up gently with a little twisting motion back-and-forth) and blow all the dust around the spark plug out so you don't get anything nasty down in the cylinders.
Your OEM plugs are NGK ZFR6F-11G, gapped at 0.042-0.044 which you can get for about $2.44 each online.
Use the anti-seize compound on the spark plug threads so you can get them out next time. Finger-thread the plugs until they are snug, then torque them to 20 N-m.
A thin coat of the silicone grease goes on the O-ring on the coil to make it easier to install in the cylinder head and to make the O-ring last longer. Install the coil on the plug, then put the 10 mm nut back on to fasten the coil down. Torque the coil nut to 8 N-m. Re-connect the connector, and go on to the next plug.
If you have the right tools, this job is easier than doing it with an old distributor/plug wires setup, and the whole thing will cost you less than $20 including the plugs, the anti-seize and the silicone grease.
Old Nov 24, 2006 | 09:52 AM
mbramble's Avatar
mbramble
Thanks guys. Finally got around to this on Thanksgiving morning. Using the info above it took about 45 minutes. I even "remembered that I forgot" to put anti-sieze on two plugs and went back and repulled them. NO problems at all.
Thanks!!
Mike
Old Feb 13, 2025 | 01:29 PM
Racc_506's Avatar
Racc_506
that’s false on 03-05 5.7 hemis they have plug wires.
Old Feb 13, 2025 | 09:47 PM
dodgetruck2's Avatar
dodgetruck2
This is an almost 20 year old thread.... how deep did you dig to find this? Most of these guys haven't even been active in the last decade
Old Feb 14, 2025 | 11:43 PM
Prismatic's Avatar
Prismatic
https://dodgeforum.com/forum/3rd-gen...ml#post3602156
Old Feb 21, 2025 | 02:19 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
