question
Old Oct 8, 2006 | 06:04 AM
AIR RAM's Avatar
AIR RAM
Default RE: question
ORIGINAL: NYPANAMA42
I have a question, for anyone who can answer it. I tried getting an answer from Air Ram, but received no reply.
what exactly are the following modifications going to do too one's truck: MARK VIII FAN; 180 T STAT; AND SAFC-II....
LOL... I replyed to your question moments after you asked? Check your PM box!
SPEED SAFE, AIR RAM
Old Oct 8, 2006 | 06:09 AM
AIR RAM's Avatar
AIR RAM
ORIGINAL: jcf1977
This may be a stupid question but what does it mean when these motors I found on EBAY say that a motor is a "N" vin number? Do certain motors only bolt into compatible vehicles? How do I tell what my truck is according to it's vin? Also, would a HEMI bolt up in my truck?
"N" is the standard 4.7L engine and "J" is an H/O engine which comes with a forged crank & higher compresion pistons, H/O cams/heads (which are not much different than the standard 4.7L heads) ... You can NOT mix the J block internals with the N block meaning you can NOT take a forged 4.7L crank and stick it into your N block... the reason is because the crank position sensors are mechined in different locations... so if you did put a forged crank in a N block... in may not even start and if it did start it would not run right at all...
The "J" block is what you want... but they are hard to find. The grand cherokee is the largest donor of the "J" block... actually I think its the only donor.
SPEED SAFE, AIR RAM
Old Oct 8, 2006 | 04:07 PM
jcf1977's Avatar
jcf1977
thanks for all the help.........................greatly appriciated
Old Oct 10, 2006 | 12:16 AM
AIR RAM's Avatar
AIR RAM
Not a problem... If you find a "J" block grab it! I always have my eyes peeled for one to build up.
SPEED SAFE, AIR RAM
