HELP, 10W40 Got in my 4.7 what to do?
Old Oct 12, 2006 | 01:21 AM
Hill202's Avatar
Hill202
Default RE: HELP, 10W40 Got in my 4.7 what to do?
oops, I did not realize a link was posted
Old Oct 12, 2006 | 01:33 AM
nos4fuel's Avatar
nos4fuel
for future referance, instead of disconnecting the negative, pull the PCM fuse and then try that. It works 95% of the time.
Old Oct 12, 2006 | 02:30 AM
cbrewer954's Avatar
cbrewer954
ya know Hill, I think we posted them at the same time. I looked back right after posting and yours was there too.
Old Oct 12, 2006 | 09:57 AM
CLEMSONTIGER's Avatar
CLEMSONTIGER
Thanks to everyone for your help.
osteo, you called it, seems to be a coincidence. I've historically had problems with this......
P0442 Evaporative Emission Control System Leak Detected (small leak)
Old Oct 12, 2006 | 03:44 PM
Stroker's Avatar
Stroker
Thats what happens when you let your wife drive your truck. Or at least thats what happens to me she never gets the gas cap on correctly.
Old Oct 12, 2006 | 06:11 PM
turbot_bird's Avatar
turbot_bird
ORIGINAL: osteodoc08
ORIGINAL: HuskyJazz
You have to turn the key on and off 3 times without starting the engine. The third time leave it on and it should post a code on you odometer.
Exactly what HuskyJazz stated. Your lights will flash and your gauges will sweep and it should pop up any codes where the digital odometer is.
will it do this on a 3rd gen dakota as well?
Old Oct 12, 2006 | 11:48 PM
vwomein's Avatar
vwomein
I have a dvd player in my truck for the kids. I left it running when I got gas
after I first got it installed, so I would not have to shut the movie off while I
gassed up. I figured I might get a check engine light & I'd deal with it later,
but it never happened. After that, I guessed these trucks were not so
"touchy"
Old Oct 13, 2006 | 01:00 AM
Hill202's Avatar
Hill202
ORIGINAL: vwomein
"touchy"
Why would that cause the check engine light to come on?
Old Oct 13, 2006 | 01:03 AM
Hill202's Avatar
Hill202
ORIGINAL: cbrewer954
you beat me by 24 sec. I knew I should've gotten the Hemi !
Old Oct 13, 2006 | 04:37 AM
Stroker's Avatar
Stroker
I think there is some type of presure sensor in the fuel tank or the vacume is needed to pull the fuel back to the tank from the regulator. But thats just a guestimation.
