whats that sound coming from the 03-06 engines
Old Oct 20, 2006 | 12:11 AM
eds2003ram's Avatar
eds2003ram
Default whats that sound coming from the 03-06 engines
I've heard a couple of 1500 rams with the same sound and was wondering if any one has figured it out yet. It is that chirping -tap sound especialy when you first crank the engine over. I also can hear it when I start to give it gas and when I step on the pedal. The dealer said it was comun engine noise for the rams especialy the 5.7 hemi. I don't buy it. A bud of mine ,with the same truck, just had his exaust manifold seals replaced and said that the dealer concluded that it was the problem. Any input would be of great help. Thanks.
Old Oct 20, 2006 | 02:45 AM
cyclone429's Avatar
cyclone429
Default RE: whats that sound coming from the 03-06 engines
I don't know....some say the 5.7 is prone to ticking, My last truck was a 04 F-150 with the 5.43v and that G D P off S was louder at idle than a cumonins or power stroke, my 06 5.7 dosent have any strange engine sounds at start up or idle, but next oil change I'm going to a synthtic oil, should quite down a little..
Old Oct 20, 2006 | 01:56 PM
kenihemi's Avatar
kenihemi
Its very common in the 5.7 engines.
You will hear it the loudest at the rear of the left front tire.
Old Oct 20, 2006 | 08:03 PM
clintmiester2's Avatar
clintmiester2
Its the lifters and valves ticking, Hemis have done it since the day they came out, even the old ones. Its just the way its built
Old Oct 28, 2006 | 02:12 AM
alrxl600's Avatar
alrxl600
I put an AEM intake on my 04 1500 Hemi and about two months later it seems to have developed an exhaust leak. I also hear that ticking you are talking about. I hope the two are not related. The dealer said it was the EGR and replaced it. The exhaust noise seems to have stopped but now it stumbles and sputters when I roll on the throttle gently, in top gear only between 1500 and 2000 rpm. If it down shifts it feels fine. They replaced the EGR again and nothing has changed. Any advice?
Old Oct 28, 2006 | 03:59 AM
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
ORIGINAL: cyclone429
Synth won't help unless you go to a thicker weight. I was running 10w30 Mobil1 and it was pretty quiet. I just switched to 0W-40 and the valve tick/piston slap is there like the factory 5W20 had until it warms up, then it's better. I use 15W50 M1 in my Cobra exclusively to keep it quiet. I don't choose oil viscosity for fuel economy. [sm=nono.gif]
I keep all my drain intervals between 3k and 4k miles.
Old Oct 29, 2006 | 09:46 AM
hemifever's Avatar
hemifever
SPONSOR
KRC Performance rebuilt my engine a few weeks ago. I put in a 6.1 cam, their 6005 series heads with manley springs and manley pushrods and some federal mogul pistons. I don't hear the tick anymore. Coltsteele's engine doesn't tick anymore either after his complete forged bottom end. Either the engine is making different noises to cover up the tick, or the tick really is gone. But I don't hear it anymore.
Old Oct 29, 2006 | 02:05 PM
Mystro's Avatar
Mystro
I have never had a Dodge Ram motor that did'nt tick or have the "valve chatter". All 318 and 360 Rams made the tick noise. The Hemi make it but it is much quieter than the 318 and 360 I had before. I would be worried if it did'nt make any noise but then again, I am a Harley guy so that explains alot.
