Lamp Out.....!!!!!!!
Old Nov 5, 2006 | 11:13 PM
  #21
Hemitough's Avatar
Hemitough
Default RE: Lamp Out.....!!!!!!!
I still cant figure out why my lamp out is on no lights are out. i bought some hid lights off ebay and put those in could it be those???
Old Nov 7, 2006 | 05:41 AM
  #22
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
ORIGINAL: Hemitough
Exactly! for the reasons 1engineer so well noted. The HID system ballast uses much less current than the stock bulb does.
Old Nov 7, 2006 | 10:44 AM
  #23
1baddodge's Avatar
1baddodge
I see this post alot inside your taillight you have that small marker light bulb it is in the upper corner. It seems everybody forgets that bad boy. Anyway I had the same problem until I changed that bad boy and never again did it ding. Also check your connections Have you changed your bulbs before, did you change your taillights? Sometimes when you pull the connectors apart you loosen up the pin inside the connector(remember don't pull by the wires pull by the connector)and that may also cause you to get a bulb out flash. I know this sounds like alot but it really isnt. Good luck and let us know.
[IMG]local://upfiles/41359/CD2B66F9EF2C43A69197BE92A8DD1EC1.jpg[/IMG]
Old Nov 9, 2006 | 02:56 PM
  #24
rolling01019's Avatar
rolling01019
hey man
check all your bulbs it did it to mine dodge 5.9L mine was a tail light out but check all your bulbs anyway
stump
Old Nov 30, 2006 | 03:13 AM
  #25
cmc033's Avatar
cmc033
I tried this and the code came up as 64 53, then changed to 00 00 after a few seconds. My driver rear brake light doesn't work. The bulbs are good. The lamp out indicator comes on. Anyone know what that code means? 02 Ram 1500 4.7 Quad.
ORIGINAL: stump_breaker
hold your trip/odometer button in and turn the key to the "on" position then let go. See what that says.
EDIT: Forgot to add the signal works with a voltage change not and actual voltage loss. You could have a bulb going out and it's already hitting on it. Look for an increased or decreased brightness in your bulbs.
