Old Aug 5, 2015, 09:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
Cleaning throttle body on 5.7
Old Oct 21, 2006 | 02:26 AM
speeddemon145's Avatar
speeddemon145
Default Cleaning throttle body on 5.7
Does anyone know how to get the throttle body to open as its opened by a motor.Pulled the cover off the top of the hemi and the throttle body is clean on the outside but behind the TB it is black as heck have 37,000 miles on it now just do not want to break anything by trying to open the Tb by hand has to be some way to get it to open for cleaning, or do I have to bring it into a shop and let them clean it rathere then spraying it out myself.
Old Oct 21, 2006 | 12:16 PM
darkrt's Avatar
darkrt
Default RE: Cleaning throttle body on 5.7
To clean it properly,you need to pull it off.
Old Oct 21, 2006 | 01:44 PM
Gone Fishin's Avatar
Gone Fishin
I agree!!!! if you force the stepper motor, you'll damage the TB-----get the procedure for cleaning from the FSM and follow it.
ORIGINAL: darkrt
Old Oct 24, 2006 | 11:09 AM
Dustin1515's Avatar
Dustin1515
you can buy throttle body cleaner spray it down with that then get a toothbrush and open the throtle body manualy then you can clean inside with the tooth brush then after that clean it out with the throttle body cleaner again and you should be good to go it may be hard to start the car after the fact of cleaning it but it will start soon enough
Old Oct 24, 2006 | 12:27 PM
motorhead426's Avatar
motorhead426
ORIGINAL: Dustin1515
No, you can only open a cable operated throttle body manually. DO NOT OPEN the HEMI throttle manually. The only way to clean it is by removing the throttle body from the intake manifold.
Old Oct 25, 2006 | 12:17 AM
Johndcjr1989's Avatar
Johndcjr1989
so youre not supposed to use the little thing on the side of the throttle body to rev your engine. cus when i installed my cai and was showing my friends i reached up there used that thing to rev the engine. sorry i dont know the correct name for the thing im talking about. also is what im describing what yall are talking about when yall say open the throttle body?
Old Oct 25, 2006 | 12:27 AM
vr6_dub's Avatar
vr6_dub
are you talking about the cable thats connected from the throttle body to ur throttle in ur truck.?
Old Oct 25, 2006 | 12:45 AM
Johndcjr1989
yeah and when you pull on it the butterfly valve in the throttle body opens.
Old Oct 25, 2006 | 11:29 AM
motorhead426
There is 2 different engines in this topic now. Originally we were talking about the Hemi, which does not have the cable linkage on the side, but rather an enclosed box for the stepper motor. The 4.7 however has the throttle cable on the side. And yes you can use that to rev up the engine, how much and how often you do it... well thats another post, haha. But do not push the butterfly (throttle plate) open on the Hemi, otherwise you WILL damage it.
Old Oct 25, 2006 | 07:59 PM
speeddemon145
[/quote]
Thanks will take it off and clean it this weekend.
