a few questions from a first time dodge owner
Old Oct 22, 2006 | 11:41 PM
02ram2500's Avatar
02ram2500
Default a few questions from a first time dodge owner
hey guys and gals...
i just bought a 2002 2500 v10 yesterday...this is my first only ever dodge..was a ford guy..totally love the truck and the crazy power. i have 2 questions...
1. my front driveshaft is moving when the truck goes in forward or reverse...and the u joints at the axel ends are locked...no free spin...is this correct, to me it seems like the truck is in 4 wheel drive? my past ford had a front driveshaft that you could spin. please help...i dont want to ruin the tires...
2. what are a good set of plug to get for a tune-up? im not used to the dodge brand...thanks alot in advance for your help...i hope i will be able to you as well...
thanks again...
chris
Old Oct 23, 2006 | 12:40 AM
motorider228's Avatar
motorider228
Default RE: a few questions from a first time dodge owner
the front driveshaft on a dodge doesn't lock and unlock like a ford. the driveshaft spins even when you're not in 4x4. i believe they have a vacuum lock kind of thing where when you engage the transfercase it locks the drive shaft in and you have 4wd. the driveline is just free spinning, no worries.
Old Oct 23, 2006 | 02:02 AM
schnydz's Avatar
schnydz
Good choice! I had a 98 2500 v10. I loved that truck. That v10 has sooo much power, I can't believe they quit offering it. My v10 rarely ever saw more that 2500rpm and it was flying with such little throttle input. Have fun!
Oh yeah, front axle disconnect. Like motorider said, there is a vacuum controlled motor on the front axle that disconnects the pass. side axle shaft so everything is spinning but it's not under load.
Old Oct 23, 2006 | 11:10 AM
02ram2500's Avatar
02ram2500
will this hurt gas mileage??
any ideas on the spark plugs?
Old Oct 23, 2006 | 11:13 AM
sneaky's Avatar
sneaky
ORIGINAL: 02ram2500
I don't know about anyone else but I only use NGK spark plugs
Old Oct 23, 2006 | 11:30 AM
02ram2500's Avatar
02ram2500
hey guys...
i just checked my friends 2500...him ujoints at the end of the axel are locked...like mine.....
but...his front drive shaft is free...should mine be too? i dont get the best gas mileage as it is...so if the front drive shaft is turning...thats no good...please let me know...thanks again
Old Oct 23, 2006 | 02:13 PM
02ram2500's Avatar
02ram2500
hey guys..
i called a dealer and they told me if i had a vacuum switch on my drive axel it wouldnt spin...i dont have this, but my friend's did...can anyone confirm this? it just seems weird to me that the front drive shaft is locked...thanks alot
Old Oct 23, 2006 | 02:52 PM
motorider228
well i know my 1998 dodge ram thats 4wd the front drive shaft always spins. also what motor do you have? dodges get bad mileage. my 98 had a 5.2 and i got 10 city 10 freeway. my 2006 hemi now gets around 15.5 so i love it.
