can you bore out engine
Old Oct 26, 2006 | 10:32 PM
dvcap2004's Avatar
dvcap2004
Default can you bore out engine
can you bore out a 2004 fuel injected 4.7L magnum engine? would it be worth it? would it be expensive? how much hp increase would there be?
Old Oct 26, 2006 | 11:56 PM
Horseapples's Avatar
Horseapples
Default RE: can you bore out engine
Sure you can,but why would you want to?A .030 over bore is only going to gain about 5 cubic inches.The only possible gain I could forsee would be to increase compression.But I would be willing to bet no one makes an aftermarket high performance piston for the 4.7.The cost of a piston manufacturer custom machining a set of blanks would be cost prohibitive.If your dead set to do this you can check with Ross,I know they will custom make a set. Be bareful to not bore over .040 this could cause overheating problems
Old Oct 27, 2006 | 01:08 AM
dvcap2004's Avatar
dvcap2004
so your saying that its not worth the extra money? and just wondering if it gave me 5 more cubic inches then about how much hp gain would that be?
Old Oct 27, 2006 | 01:45 AM
Horseapples
The expense would in no way justify the 7 or 8 HP you might gain.I would spend the money on A down payment or trading your truck in on one with a 5.7L. The cost of making as much power as the 5.7L would be twice as much as just getting a truck with a Hemi.If I were you I would put a cold air intake and a good exhaust on the 4.7 and just enjoy the truck instead of trying to turn it into something its not,nor was designed to be.
Old Oct 27, 2006 | 01:14 PM
motorhead426's Avatar
motorhead426
I don't know if I fully agree with the 7-8 hp increase. Take a look at the Chevy 350, when bored out to 355 it can produce a very noticable power gain. The other thing you might consider is having the heads shaved to increase the compression. What is the stock compression on a stock 4.7? Just make sure you run the octane gas in it after doing so.
Old Oct 27, 2006 | 01:38 PM
Horseapples
The hi po pistons available for the 350 chevy are in the hundreds,a few cubic inches one way or the other does not make much difference.Its what you put in the holes after the machine work is done that counts.As far as shaving the heads to increase compression,one would also have to shave the intake to match the new head angle.I would take it to a top level machine shop to have this done.You would need someone that understands angles and formulas or you could end up with vacuum and water leaks.I have seen lots of bad attempts to to this turn into ruined heads,so make sure its someone that deals with this stuff on a regular basis.
Old Oct 27, 2006 | 02:05 PM
motorhead426
ORIGINAL: Horseapples
Can't disagree with that!
Old Oct 27, 2006 | 04:42 PM
20brewcity02's Avatar
20brewcity02
http://krcperformance.com/newcontent/47page.html
check them out for hi comp forged stuff as well as cams
Old Oct 27, 2006 | 08:11 PM
Gone Fishin's Avatar
Gone Fishin
If you really want to build HP, why not leave the engine as is and install an STS turbocharger system and properly sized exhaust. By the time you're done with the performance rebuild like you're considering above, I have to imagine you'll be spending nearly the same coin.
Just my .02
Old Oct 28, 2006 | 02:27 AM
raidermike67's Avatar
raidermike67
>>>>>>>>>>>>&g t;
Personally, I don't believe in messing with mother nature too much, never know what to expect.
