Anyone run into tail light problems
Old Nov 15, 2006 | 12:03 PM
gpzjack's Avatar
gpzjack
Default Anyone run into tail light problems
The other day my 04 had a brake light go out. Replaced it and it went right out again. Had my friend look at it and it appears that the unit the bulbs go in is bad. Im getting power up thru the harness but nothing at the socket. My regular dealer is almost an hour away so im gonna try to another local dealer
Old Nov 15, 2006 | 03:03 PM
Dire Wolf's Avatar
Dire Wolf
Default RE: Anyone run into tail light problems
I think this happened to me last wk. Replaced a brake light bulb and it went out right away. Havent tried to replace it again, been too busy. Lamp out light has been on for weeks.
ORIGINAL: gpzjack
Old Nov 15, 2006 | 05:21 PM
gpzjack's Avatar
gpzjack
I tried to put another bulb in and it doesn't work. I even tried swapping other bulbs from the tail light and it doesn't work. Im going to the dealer in the morning. Im gonna see about trading it in while im there.
Old Nov 15, 2006 | 10:05 PM
HemiLonestar's Avatar
HemiLonestar
I blew a couple of bulbs in a row because it wasn't getting good contact. Once I modified it a little, no problem since.
Old Nov 16, 2006 | 12:23 AM
Topher7999's Avatar
Topher7999
same thing happened to me and the light out bell kept on ringing, u need to change that whole outlet thing behind the taillight bulbs may also do the trick
Old Nov 16, 2006 | 08:09 PM
gpzjack's Avatar
gpzjack
Just got back...It was the thing the bulbs go in ...sounds like a pretty common problem....Almost traded her in while i was there. LOL
Old Nov 16, 2006 | 08:56 PM
BgBluRam's Avatar
BgBluRam
How much is the new socket for the bulbs? I had one taillight melt in the socket because of a bad connection and it got hot. I fixed the connection and have not had a problem since, but just curious for future reference.
Old Nov 16, 2006 | 09:06 PM
Drudwn2000's Avatar
Drudwn2000
Yep, I had the same problem. I went through like 3-4 bulbs. I just sopped caring and It has been working ever since. It seems like it is a problem every now and again. How much did you pay to get the socket piece replaced?
Drew
Old Nov 17, 2006 | 12:28 AM
Parts/Service's Avatar
Parts/Service
The taillight "strip" on the back of the taillight is a very common problem. I sell alot of them. The part # is 55077343AD. Should cost about $20.00. If your local dealer isn't any help, call me and I can ship you them UPS. Best to replace them both at same time as they ARE gonna cause problems until you replace them.
David
James O'Neal Dodge
1-800-663-2522
Old Nov 17, 2006 | 08:28 PM
gpzjack's Avatar
gpzjack
Fixed under warranty! Good to know they are only $20....It cost me more in time missed from work to get to the dealer. If it happened again i would just buy them.
