4X4 dash light
Old Dec 22, 2006 | 10:37 PM
cableguy1224's Avatar
cableguy1224
Default 4X4 dash light
Hello,
Today we had some good snow, I put the truck in 4 wheel drive and saw the 4X4 light come on and then a little while later when I put it baack in 4 wheel drive the little light wont come back on, I did check on the ICE and the 4 wheel drive is working but just not the light, Its an 05 with 7000 miles one 7 thousand not 70,000
Any one ever seen this or the fix for it?
THank you
Old Dec 23, 2006 | 01:59 AM
diehardpolice's Avatar
diehardpolice
Default RE: 4X4 dash light
My best guess is that the light itself is just blown. If the four wheel drive is still working I don't know what else it could be. just my .02 cents
Old Dec 23, 2006 | 03:18 AM
awroberts's Avatar
awroberts
Mine does the same, but the light comes back on when I wiggle the handle.
Old Dec 23, 2006 | 05:39 PM
cableguy1224
yeah I tried the wiggle method, Im pretty sure for $31,000 a year agoI will make them fix it, The truck only has 7,000 miles on it
Old Dec 23, 2006 | 06:22 PM
boxerdiesel's Avatar
boxerdiesel
Just so you know mine did the exact same thing. There is a sensor/switch that most likely went bad, It was covered under the warrentee and only took the dealer 1/2 a day to fix.
Old Jan 21, 2007 | 04:21 AM
cableguy1224
Yeah it was the switch, was fixed for free too, Thank you for the input
Old Jan 21, 2007 | 04:25 AM
Hellbilly1's Avatar
Hellbilly1
cableguy, when you debadged your truck did you just use heat i assume??
Old Jan 21, 2007 | 01:55 PM
cableguy1224
yeah what I did was, 1 I heated one emblem up at a time with a blow dryer, then I took a little tiny flat head screwdriver and put the end right under the edge of the emblem and WITHOUT touching the paint I just pulled in an out ward motion and popped them off one by one, Very easy job, just getting the 3M tape off was the only tricky part, Again I used heat to get the bolk of that off then followed by a goo type remover,
Also you can get the emblems off by using some strong fishing line and use a sawing motion to cut them off, I tryed that first but I think the fishing line I had was to catch minnows, it kept breaking. So the screw driver tricked very well for me, you just have to be very carefull you dont touch the paint and use enough heat to goo the emblems.
Sorry to ramble I hope this helps you, let me know if you have any question and make sure and let me know when complete so I can see a few pictures of your ride
Have a good one man!!
Old Jan 21, 2007 | 08:53 PM
Hellbilly1's Avatar
Hellbilly1
that was my main question was the goo after wards i was wondering if any of the removers also well removed paint
Old Jan 21, 2007 | 11:51 PM
cableguy1224
The stuff I use is called cableclear, I had some in my work truck, Its a very citrus smelling stuff and works magic on many things, you can find it at http://www.cableclear.com/Also goo begone works good, and lat but not least a good bug and tar remover works ok, but my far cable clear is the best for EVERY THING I have ever used it on
Hope it helps
