Anyone install a catch can on their hemi ?
Old Dec 27, 2006 | 01:09 AM
9SEC6SPD's Avatar
9SEC6SPD
Default RE: Anyone install a catch can on their hemi ?
got it! is the secondary spark mainly utilized to reduce emissions? just what i have heard
i wonder if msd makes coil packs for the hemi's. i will check it out!
Old Dec 27, 2006 | 01:47 AM
SlickHemi06's Avatar
SlickHemi06
And the advantage is? Or maybe i'm just a dumb confused kid [sm=boohoo.gif]
Old Dec 27, 2006 | 09:13 AM
HankL's Avatar
HankL
Worth a read
about how many items on the 5.7 Hemi works
including the 'wasted spark' ignition
with many excellent pictures and cutaways
http://www.popularmechanics.com/auto...s/1266926.html
sample quote
This is the spark plug wiring harness for one cylinder bank of the Hemi. Being a modern waste-spark ignition system, when the plugs fire after compression for the cylinder on the power stroke, its companion cylinder on the other bank fires its plugs during the exhaust stroke. Why? Because wiring the system this way requires only eight ignition coils to fire all 16 spark plugs, keeping costs down....
2. The dual spark plugs in each cylinder fire just about simultaneously. This does not cause detonation, because the flame front from each spark promotes a controlled burn designed for more-effective combustion, good emissions control and stable idle quality.
Old Dec 28, 2006 | 08:26 PM
9SEC6SPD's Avatar
9SEC6SPD
better spark, more voltage, etc... the way i see it is too much spark is not a bad thing. coils recover quicker as well, especially if the short wires are being used... i would think. i hope that made sense.
