New electric fan---FYI
Old Dec 27, 2006 | 10:01 PM
Gone Fishin's Avatar
Gone Fishin
Default New electric fan---FYI
I was looking throught he truck section of the new Summit Catalogue today and noticed that Perma-Cool pg 370, has a new full cowl mount electric fan for 2004-07 v6,8,10 cyl.Ram. Its supposed to bolt up to the OEM mounting. Seems kinda expensive to me ($549.95), but thought you folks might be interested.
Old Dec 27, 2006 | 11:46 PM
helopilot's Avatar
helopilot
Default RE: New electric fan---FYI
Can you do me a favor and find the part number? I can't find it on the website anywhere.
Old Dec 28, 2006 | 12:10 AM
djr04's Avatar
djr04
try PRM-19521
Old Dec 28, 2006 | 12:12 AM
NYPANAMA42's Avatar
NYPANAMA42
Can someone tell me, what exactly does this fan do? And why is it beneficial?
Old Dec 28, 2006 | 12:59 AM
helopilot's Avatar
helopilot
ORIGINAL: djr04
try PRM-19521
Zero, zilch, nada...not showing up there or anywhere on the web. It's not even showing up on Perma-cool's website.
Old Dec 28, 2006 | 01:07 AM
weswing04's Avatar
weswing04
ORIGINAL: NYPANAMA42
It cools your engine
Beneficial because it isn't using engine power to turn it. i.e. more horsepower.
Old Dec 28, 2006 | 04:15 AM
chefred112's Avatar
chefred112
...yup, what he said...by taking the stock fan off the crank it lessens the crank drag, it's an obvious and noticeable performance mod...i'm still smilin with mine...
Old Dec 28, 2006 | 07:51 PM
NYPANAMA42's Avatar
NYPANAMA42
I guess i'm out of my league on this one.........I see most of you guys have Hemi's, so i guess this fan is specifically made for Hemi's.
I get Summit catalogs periodically, so I'm going to check and see if i can find one of these fans for my truck.
Can anyone advise as to what type of fan i should be looking for?
Old Dec 28, 2006 | 08:56 PM
Gone Fishin
Sorry Guys,
I guess I should have elaborated more. The part # PRM-19521 is correct. I couldn't find it on the Summit web site either---they just haven't put it up yet. I found it in the most recent catalogue--pg 370.
It replaces your stock engine driven cooling fan behind the radiator. By doing this you get rid of some parasitic lost of power, that is normally required to drive the fan---by going electric--you free up more horsepower!!!! Since the Dodge fan is actually driven all the time, as I understand it, you will gain horsepower thoughout the RPM range---or another way of looking at it is you'll get a little better mpg if you keep your foot out of it. It is a temp adjustable fan that also has a relay that turns the fan on when the A/C is turned on. It also comes with its own shroud, so you pull the old, mount the new, wire it in and your ready to go.No chopping and hacking at the OEM shroud to mount it.
OK, I hope that explains it better
Old Dec 29, 2006 | 03:22 AM
NYPANAMA42's Avatar
NYPANAMA42
Thanks for the info, Gonefishing
