rear end
Old Dec 31, 2006 | 07:01 PM
Ketchup's Avatar
Ketchup
Default rear end
does the 02 quad 2wd 4.7 come with LSD or something. when i first got it i tried it in some dirt and both turn and now it feel like they take turns and i keep hearing a click noisy when i go into gear only in drive not revers.
Old Dec 31, 2006 | 09:50 PM
superdak05's Avatar
superdak05
Default RE: rear end
open your glove box and look at the back. there should be a parts list to what rear and gearing you have in your truck. if not take down you vin # and bring it to the dealer and they will be able to tell you.. also you may have snapped you carrier rings to the diff. might have to go to the dealer to check that out
Old Jan 1, 2007 | 06:05 PM
Ketchup's Avatar
Ketchup
just look at the paper and it said that i have 3.55 and lock diff. but what is a mult speed tranny. my friend has the hemi and his said something different but everything else was the same. his say all 5 speed
Old Jan 1, 2007 | 08:13 PM
loiler921's Avatar
loiler921
sounds like your rear end is getting ready to blow out.....i know cause it just happened to me
Old Jan 2, 2007 | 01:28 PM
Ketchup's Avatar
Ketchup
what can i do to save it or how much is another one
Old Jan 2, 2007 | 02:22 PM
motorhead426's Avatar
motorhead426
I would definitely take the rear cover off, and see if the LSD clips have broke yet. A doner axle that I just bought had broken clips and another one I saw on Friday at the dealership had some broken clips also. Normally the clips is not detremental, but these clips got hung up between the Carrier and the bearing cap, which caused a deep groove into the bearing cap, and LOTS of metal shavings. As soon as I get the pics off of my camera at lunch I'll post some of what I found.
Old Jan 2, 2007 | 04:32 PM
motorhead426
check out the pics I just posted. These would make me get that cover as fast as possible and inspect the inside...
https://dodgeforum.com/m_660218/tm.htm
Old Jan 2, 2007 | 06:23 PM
Ketchup's Avatar
Ketchup
i dont have my warnty no more. i knew that was going to happen i am at 98 000. what else usaly go wrong or do i need to trade it in and get another dodge and be up side down
Old Jan 2, 2007 | 11:17 PM
Ketchup's Avatar
Ketchup
what is a locking diff. is it lsd
Old Jan 3, 2007 | 04:06 PM
abarmby's Avatar
abarmby
Yeah.
Dodges don't have "locking diff's" as standard.
What we 1500 guys have if bought as an option, is a poor LSD which has many issues of both bad design and poor quality.
The retaining clips, commonly refered to as "C clips", come loose and foul up the carrier end caps by grinding away at them.
This causes irreversable danamage to the whoe axel, including wheel bearings etc due to the lubricant being contaminated with fine metal etc, which necessitates the COMPLETE removal and replacemarnt of the unit except for your brake shoes, which are not covered under any warranty.
It's a bummer and one which I and MANY Dodge owners, have filed a report on the http://www.nhtsa.dot.gov/web site.
I ENCOURAGE ALL Dodge 1500 owners with the LSD option, to log a complaint with these people.
Dodge/Chrysler/Mercedes or whatever they call themselves these days, really need to get on top of this issue before somone is killed.
A corporate manslaughter suite is not the way forward if you want to sell trucks or cars Dodge!
Or is that just it.........you want to DODGE the issue?
I have just read an article where a Dodge owner had his diff go out at about 30mph and when the truck finished hopping and fishtailing around narrowly missing other cars and the Armco etc..............well as he stated and I quote "it's a good job I wasn't on the freeway doing 70"???????
Can you imagine a totally locked out diff at 70mph?
WOW!
We LSD guys are running around with a grenade inour diffs waiting to EXPLODE!
So, come on people, log those complaints with the NHTSA.
Dodge might........and should,,,,,,,,isue a recall!
Al.
