diff lockers on none powerwagon
RE: diff lockers on none powerwagon
From the Dodge service manual:
There are four wires on each solenoid:
1. FRONT LOCKER SOURCE
2. LOCKER SENSOR SUPPLY
3. FRONT LOCKER SENSOR SENSE
4. FRONT LOCKER RETURN
OR
1.REAR LOCKER SOURCE
3.REAR LOCKER SENSOR SENSE
4.REAR LOCKER RETURN
OR
So, is it as easy as:
Connecting Ground to #4 and connecting a switched+12 volts to #1?
and
Optionally connecting+12 volts to #2 Sensor supply if you want an idicator signal back on #3?
Let me know how you make out...and of course how much better your truck does off road.
and
correct, accept #2 is + 5volt (it a sensor) and #3 is the sensors (-) ground....
They work great, i just put them on a toggle switch w/ a relay
Also, simple install. i have an 04 2500 and there was no grinding of the front diff , like i've read.
Just remember the front ring bolts are reverse threaded!
