LIGHTS WONT COME OUT TO REPLACE THE BULBS
Old Jan 28, 2007 | 08:19 PM
pakaalbite's Avatar
pakaalbite
Default LIGHTS WONT COME OUT TO REPLACE THE BULBS
I have an 05 ram and i have xenon lights that im putting in. I took out all the bolts that hold the light in(i think) but it still wont slide out. Please help me and tell me if im doing anything wrong. I removed the three bolts
Old Jan 28, 2007 | 08:27 PM
vwomein's Avatar
vwomein
Default RE: LIGHTS WONT COME OUT TO REPLACE THE BULBS
there is one push in clip on each fender to hold the light in. its a pretty stiff clip, but it will pull out
Old Jan 28, 2007 | 10:27 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yah it's just held in place by (3) 10mm bolts and then just pull it out as mentioned above
Old Jan 28, 2007 | 11:01 PM
pakaalbite's Avatar
pakaalbite
WHERE EXACTLY IS THIS CLIP LOCATED????
Old Jan 28, 2007 | 11:15 PM
Jetpig's Avatar
Jetpig
If you are just replacing bulbs, you do not have to remove the light housing, only the socket in the back of the housing, accessed from under the hood.
Old Jan 28, 2007 | 11:19 PM
05_FL_RAM's Avatar
05_FL_RAM
there is no need to remove the light housing ....the bulbs are removed from the rear side of the light.
screw on collar and spring clip are all that need to be releases on the back.
as mentioned.... this applies to bulb replacement applications only.
Old Jan 28, 2007 | 11:30 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yah, but it's much easier to do it with the housing removed and its only 3 screws
Old Jan 28, 2007 | 11:35 PM
motorider228's Avatar
motorider228
Yeah it's easier to do with the housing out but it's still in no way difficult with the housing still in the truck.
Old Jan 28, 2007 | 11:39 PM
hemiyellow's Avatar
hemiyellow
DC Insider
true enough
