Heat problem!
Old Jan 30, 2007 | 04:37 PM
Rampower's Avatar
Rampower
Default Heat problem!
Hey guys, my heat seems to work only at higher RPM levels. If i sit there and let it idle it will blow cold air. I'm thinking coolant level... Any suggestions?? 2002 1500 4.7L 124000 KMS. Thanks guys!
Old Jan 30, 2007 | 04:44 PM
whitey97's Avatar
whitey97
Default RE: Heat problem!
i bought my 07 with the 4.7 not too long ago, and my heat sucks in that as well, is yours something that has gotten worse? or has it always sucked? if it's something that's gotten worse, flush the whole bish, replace the coolant if desired or just top it off, and try replacing the termo. if that doesn't kick it, i'd have the techs read your info while it's running.
Old Jan 30, 2007 | 05:59 PM
Rampower's Avatar
Rampower
No i just started to happen.... wouldnt the coolant light come on if it was low?
Old Jan 30, 2007 | 06:03 PM
whitey97's Avatar
whitey97
who knows, it's supposed too, doesn't mean it's going to. nothing beats eliminating possibilities than checking it yourself. besides, what are you out by checking it? maybe 10-20 seconds?
Old Jan 30, 2007 | 06:19 PM
Rampower's Avatar
Rampower
I have no prob checking it... just did actually, doesnt even show in the overfill bottle... what coolant does the 4.7 take by the way?? thanks again for the?
Old Jan 30, 2007 | 07:39 PM
Foiled's Avatar
Foiled
Let the engine cool and open the Radiator cap. If you no not see water add some. I am sure your coolant % will be fine unless you add more then 1 gallon, then add water to the over flow to the bottem line. But if you are not sure that you had plenty of antifreeze in it just do a 50/50 mix.
My 06 Hemi has the orange antifreeze coolant in it. I am not sure of the 4.7 but you need to try and match it.
Old Jan 30, 2007 | 07:43 PM
Foiled's Avatar
Foiled
I just remembered, Dex-Cool is the orange stuff. Green is the normal. Just pick one of them.
Old Jan 31, 2007 | 01:08 AM
reiderr's Avatar
reiderr
Guys,
DON'T use Dex-Cool. Orange is just a color. The Mopar "orange" coolant is actually quite different than Dex-Cool. Dex-Cool is considered too corrosive for Mopar applications. If you can't/won't get Mopar coolant, then get Zerex G-05 coolant. If you have to go with the other long-life coolants, then you'll probably need to flush first or plan on a flush soon in the future. I've seen Zerex G-05 at Napa and Pep Boys around here. Also, buy "distilled" water only to mix/dilute the coolant. Don't use tap water if at all possible. Personally, I'd stick with Mopar for top-offs just to be on the safe side.
BTW, I used Dex-Cool in my wifes Caravan V6. It ate 2 water pumps and one timing cover gasket before I realized the mistake. Won't do that again...
Old Jan 31, 2007 | 01:59 AM
whitey97's Avatar
whitey97
oops...... that was a big mistake...
"rampower" don't take me as being offensive, sometimes i come off on here as a dink, sorry
Old Jan 31, 2007 | 03:07 PM
Rampower's Avatar
Rampower
No problem whitey97.
