Power steering pump
Old Feb 4, 2007 | 03:23 PM
usnfirefighter's Avatar
usnfirefighter
Default Power steering pump
Today I noticed when I was changing my oil, that where the power steering is ( I think it is the pump) That there was some fluid where the lines come into it. My truck had 34500 mi. Is this a common problem or what. I also noticed some fluid on my tailgate once before, but didn't think anything of it because I had just changed the oil. Thought it may be residual, but it happened again. Any help would be appriciated.
Old Feb 4, 2007 | 03:27 PM
usnfirefighter
Default RE: Power steering pump
I forgot to mention, it's a 2004 QC.
Old Feb 4, 2007 | 03:33 PM
Scootr's Avatar
Scootr
I'd clean off all the fluid to get a better idea of where it might possibly be leaking from. Have someone sit in the truck with it running and move the steering full turn back and forth. Look to see if there is anything leaking in that area.
Old Feb 4, 2007 | 03:47 PM
matsram's Avatar
matsram
just had the same problem the mech said sometimes its the lines or its the front pump seal mine was the pump seal it would drip on to the rack and pinoin where the hoses attach at first it was small then it totally let go coming home from up north last weekend i went through 4 quarts in 300 miles and the bottom the truck is covered in oil it took two underbody car washes with degreaser to come clean my pump was 91 dollars and labor was 120 i would have done it myself but its too damn cold for that.
Old Feb 4, 2007 | 04:56 PM
usnfirefighter
It looks like it's a very very small drip where the lines come into. Ya think I shoud try to tighten it or just say screw it and go to the dealership.
Old Feb 4, 2007 | 06:09 PM
atlaticblueram's Avatar
atlaticblueram
i have an 02 ram and mine is leaking as well. but mine started at the rack and pinion. it then started leaking at the high pressure hose at the pump. i pinpointed mine to the fact that it is lifted and it requires more pressure to steer the bigger tires. btw it has 49000 miles on it.
Old Feb 4, 2007 | 09:31 PM
usnfirefighter
After you said about a bigger tire, I'm wondering if that was my problem. I checked my tires and I was at 28 PSI. The truck came with 245/70/17 and I got 265/70/17 tires. I bumped the PSI to 37. Truck recommends 35, but that was with stock tires, and the mak psi on the tires now is 44. I was asking about tire pressuer in another topic. Maybe that was the problem. I'll just have to se.
Old Feb 5, 2007 | 01:04 PM
NYPANAMA42's Avatar
NYPANAMA42
Yeah, alot of vehicles especially the Quad Cabs, have been experiencing problems with Power steering fluid leaks.
If you do a search on the forum, you'll see several posts on the topic.
Old Feb 9, 2007 | 03:19 PM
usnfirefighter
Alright, I took the truck to the dealership and they fixed the leak on my power steering pump. They asked if I wanted the 30,000 mi main, and asked about spark plugs. Should I change my plugs, I thought they were good for like 50,000mi.
Old Feb 9, 2007 | 07:32 PM
hemirambob's Avatar
hemirambob
30,000 miles on the plugs. Had 2 hoses replaced on my 04 and 1 steering rack. LOTS of problems with these.
