Borla exhaust for dodge Ram 1500 2002
Old Feb 4, 2007 | 05:29 PM
franki374's Avatar
franki374
Default Borla exhaust for dodge Ram 1500 2002
Hello,i want to know if i can install a borla exhaust system on a Dodge Ram 1500 2002,4.7 litres.I want to install the one like the Ram Daytona 5.7 litres with single inlet and dual outlet on my 4.7 litres.Is it possible and what about performance and sound.Thanks.
Old Feb 6, 2007 | 07:17 AM
UncleRocketCoaster's Avatar
UncleRocketCoaster
Default RE: Borla exhaust for dodge Ram 1500 2002
I have a Borla cat back duel exhaust. I got it from Summit racing. Sounds great under acceleration then when you hit cruising speed it sounds the almost same as stock. As for performance the Borla with the K&N I have a noticable gain in power, and better highway gasmileage. Went from about 16.5 miles/gal to 19!
Old Feb 7, 2007 | 03:49 AM
franki374's Avatar
franki374
Hello and thank you for the answer.Do you have the same motor as mine,4.7 litres?
Old Feb 7, 2007 | 05:04 AM
motorider228's Avatar
motorider228
yes his signature says 4.7 liter.
Old Feb 13, 2007 | 03:56 AM
franki374's Avatar
franki374
Do you know if i need an adaptor or a reducer to install the cat back system like yours?thank you.
Old Feb 13, 2007 | 10:27 AM
UncleRocketCoaster
All I had to do was remove the old muffler and tailpipe and bolt on the Borla system. It came with everything needed to install it.
Old Feb 16, 2007 | 03:46 AM
franki374's Avatar
franki374
Thanks,what is your K&N,is it a P FLOW or a cold air intake?I have one MAC p -flow and a jetpower chip on the truck,the sound is change but do you think it will be louder with the borla system?
Old Feb 16, 2007 | 04:04 AM
UncleRocketCoaster
My K&N is cold air intake. I put the Borla on firstand it much louder than stock, about a month later I put on the K&N and it got even better! So yes, if your changing out a stock muffler it will be louder.
