Old Aug 7, 2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension
Print Wikipost
topped up with wrong power steering fluid
Old Feb 11, 2007 | 01:15 PM
T Man's Avatar
T Man
Default topped up with wrong power steering fluid
I noticed that my power steering fluid was low and I topped it off with about 2 oz of regular power steering fluid instead of the ATF+4 transmission fluid (should have checked the manual first, I know).
Will this small amount harm anything or should I change the fluid all together?
Old Feb 11, 2007 | 03:19 PM
NYPANAMA42's Avatar
NYPANAMA42
Default RE: topped up with wrong power steering fluid
I would drain the power steering fluid, then REFILL with the proper PS Fluid.
Old Feb 11, 2007 | 08:10 PM
aaronstottle's Avatar
aaronstottle
I'll second that.... Don't leave that stuff in there!
Old Feb 11, 2007 | 09:13 PM
mazz's Avatar
mazz
Ditto
Old Feb 11, 2007 | 09:56 PM
T Man's Avatar
T Man
Do I need to flush it, or just empty and refill what is in the reservoir?
Old Feb 11, 2007 | 10:10 PM
BigNelly07's Avatar
BigNelly07
if you have not driven the vehicle, you can just remove whats in the reservoir and replace with new. BUT, if you have driven it, you will need an entire system flush of the power steering system.
Old Feb 11, 2007 | 10:17 PM
T Man's Avatar
T Man
I'm not doubting that I need to change the fluid, but what harm could 2 oz. cause in the system? Could it affect seals, etc?
Old Feb 11, 2007 | 10:27 PM
hemiyellow's Avatar
hemiyellow
DC Insider
well, here's what it says right from the service manual:[align=left]CAUTION: MOPARATF+4 is to be used in the[/align][align=left]power steering system. No other power steering or[/align][align=left]automatic transmission fluid is to be used in the[/align][align=left]system. Damage may result to the power steering[/align][align=left]pump and system if any other fluid is used, and do[/align][align=left]not overfill.[/align][align=left][/align][align=left]so i would agree with what everyone else has said and I would flush the system and refill with ATF+4[/align]
Old Feb 12, 2007 | 12:54 AM
JMesel32's Avatar
JMesel32
I am glad i was checking this out tonight because i just did the same thing today. I have never drained the power steering fluid. I haven't taken a look yet to try to figure it out but if someone could let me know that would be great. Thank you.
Old Feb 12, 2007 | 02:32 AM
vinman966's Avatar
vinman966
Ooops! I did the same thing too
