Door Panel Removal
Old Feb 19, 2007 | 06:13 PM
cr80renob's Avatar
cr80renob
Default Door Panel Removal
I am looking at replacing the speakers in the door. But before I do that I have a couple questions, How do you remove the inside door panel? Also, I want to replace the speakers behind me (Regular Cab Truck), How do I get to those? Thanks in advance for your help.....
Old Feb 19, 2007 | 06:17 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: Door Panel Removal
dont want to type that much so go to www.hemitruckclub.com and download the service manual
Old Feb 19, 2007 | 07:48 PM
kvn_rivers's Avatar
kvn_rivers
is wat you need to do theres two screws on the bottom of the panel 1 on the top right (drivers side) and you needa take off the door handle with a 8 point star tip pull up unplug wat needs to be unplugged and your done
Old Feb 19, 2007 | 09:39 PM
morrjr's Avatar
morrjr
I can give you directions for the door speakers (I did mine a couple of weeks ago), but not for the rear speakers on a standard cab (I have a QC).
Remove two screws at the bottom of the trim panel; one screw by the side rear view mirror; and one screw by the door handle. The door handle is held on by a #40 torx head bolt. After all screws and bolts have been removed, carefully lift the trim panel straight up and pull towards you just enough to get your hand behind the panel to unplug the power window and door switch connectors.Setthe trim panelaside and do your work. Reinstall using the reverse procedure.
Old Feb 19, 2007 | 10:59 PM
cr80renob's Avatar
cr80renob
I don't have power door locks or windows. So how do I get the hand crank off?
Thanks a lot for your help.....It doesn't seem to be too hard
