Gears
Old Feb 24, 2007 | 03:37 PM
Midnightrider's Avatar
Midnightrider
Default Gears
I have a 2006 Ram.. have done a few minor mods to it and am now looking to do gear. I would like to go as extreme as 4:56 but I have run into a problem. I can get the gears but I can't seem to find a tuner that can tune my Tranny for them. As I read through some of the posts I have noticed that some of you have done gears and was curious as to what tuner you used. Any help would be greatly appreciated. Thanks.
Old Feb 24, 2007 | 04:20 PM
helopilot's Avatar
helopilot
Default RE: Gears
On our trucks you do not have to tune anything to put in gears. The only thing you will ever have to worry about is reprogramming the speedo for a different tire if you change sizes.
By the way 4.56's rock...even with 30" tires!!!!
Old Feb 24, 2007 | 04:55 PM
deanj287's Avatar
deanj287
Default RE: Gears
and the dealer ship will re calibrate the speedo for free
Old Feb 24, 2007 | 05:51 PM
motorider228's Avatar
motorider228
Default RE: Gears
Our trucks don't read for the speedometer off of the gears, they do off the wheels so you don't have to adjust the speedo for gears, only tires. Also, our transmissions don't need to be tuned either for gears.
Old Feb 25, 2007 | 11:26 PM
Midnightrider
Default RE: Gears
Ok thanks alot everyone, for you input. Saves me a good amout of $$... <3 Dodge
Old Feb 25, 2007 | 11:41 PM
Midnightrider
Default RE: Gears
One more question, for those of you who had 4:56's what is your crusing speed on the highway and also what is your topspeed roughly?
Old Feb 26, 2007 | 12:18 AM
helopilot's Avatar
helopilot
Default RE: Gears
ORIGINAL: Midnightrider
Cruising speed or cruising RPM? I usually cruise about 85 mph or so and as far as top speed...143 according to the GPS and the pegged speedometer.
Old Feb 26, 2007 | 01:49 AM
Midnightrider
Default RE: Gears
Cool, whats your Rpms roughly @85mph... just trying to figure everything out before i acutally go out and do it. I don't wanna be screaming the motor down the highway.
Old Feb 26, 2007 | 04:10 AM
BgBluRam's Avatar
BgBluRam
Default RE: Gears
At 85mph my RPM's are about 2500... I also have 35" tires so it may be a bit higher (like 2800-3000) with a stock 30-31" tire... You'll love the gears.
Old Feb 26, 2007 | 10:25 AM
helopilot's Avatar
helopilot
Default RE: Gears
2900ish at 85 mph
